New builder - looking for alternative PC case after intended one has gone out of stock
4 Feb 2022
United Kingdom
E: It's done. All parts have been bought and I am now waiting for them to be delivered. In the end I chose the MSI mag forge 100M.
Heya. A couple months ago I asked for help with an IGPU computer build, and with the assistance of several commenters, was able to build a list as seen below. I now have the money to begin buying parts - but now that I'm looking at the website, the PC case that was suggested (BitFenix Nova Mesh SE ATX Mid Tower Case) has now gone out of stock. I have about £40 left in my budget to get a different case, but there are so many different cases out there that I just have no idea what the best option is. I would much appreciate any guidance from here, and thanks in advance.
Any suggestions to upgrade/reduce prices for other parts are welcome too, but it could do with staying in budget where possible. I can perhaps go £20 over the original £610 limit if there's an upgrade that would hugely benefit the build, but nothing more than that though. I would also like to get this sorted by tonight, as I'm somewhat on a time limit to get a PC up and running before my laptop packs up for good.
CPU: Intel Core i5-12500 3 GHz 6-Core Processor (£197.99)
Motherboard: Gigabyte B660M DS3H AX DDR4 Micro ATX LGA1700 Motherboard (£113.68)
Memory: PNY XLR8 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (£116.33)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive (£81.46)
Case: BitFenix Nova Mesh SE ATX Mid Tower Case
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply (£59.99)
Total: £569.45
What's you using the pc for, any plans to game ?
Dropping to 16gb of memory will free up funds.
Digital art first and foremost, and I want to move into some more intensive 3d modelling in Blender when I can afford a GPU later on. IIRC I was told the RAM may be a good investment with this in mind.
Fair point was just trying to free up funds to improve in other areas. Psu is only 550w which may be a bit limiting for gpu choices depending on how high end you want to go.
Good point. I don't think I'd be going for a higher end GPU, or if I did I would be doing it a loooong time in the future, so I think for now it's probably going to be okay. I'll bear that in mind though, thank you
