I expect they are which is why I put the date, but there are enough scaffolding firms around, so get quotes, why just let the solar installer add another x% on top for making a few phone calls?
(no car charger but I'm not too bothered about that as there is funding available to reduce the cost of that a lot if I need one when I get an EV).
Where is that available?
TBH organising scaffolding myself opens up the possibility that it's not done how the installer needs it and it causes delay and liability on my side for any delay. If the installer is taking a few %age points for organising scaffolding then fair enough, the overall liability remains with the single company I am paying and organising everything.
The overall price of £6k for a 3.12 kW system seems a bit high compared to the other indicative estimates I've had for a 4 kW setup at the same cost. I feel there might be a bit of haggling available in the first quote though, going to give it a couple of days to see what else I get offered.
Put in an application to our DNO for a 10kW battery-backed system this week, turns out they won't allow more than 3.68kW unless either they upgrade the network equipment or we pay £40k+ for a new substation somewhere. Solar power, it's the future!![]()
Can't you just limit the export to 3.68 on the inverter?
Read same for me, exact figure. How many panels gets to this cap?
does seem a bit crazy, and typical they try and pass on the costs to you! You kind of need to be able to throttle the feed in to the network don't you...
THEN you have to limit the discharge capability on the battery which just shifts the problem.
Average payback on solar used to be between 11 and 13 years. Given the rising cost of energy, what is the current payback on Solar ?
Not much, without a battery its 10 x 365w panels through a single 3.68kW inverter.
OK thought about it a little and realised you can probably generate more (have more panels) but have a limiter and battery setup so that the export is restricted?
As it has been in place for years I imagine it has to be so otherwise you would see less coverage on roofs and the installers would be plastering disclaimer limitations etc.
Installers can limit supply to the grid, if you don't store the excess or use what is generated it's just not as efficient
N
I'm still learning on all of this but yes, you can have a 3.68kW inverter but then your clipping energy from the panels (i.e. over-generation), you then need to add battery storage charging directly from the panels but THEN you have to limit the discharge capability on the battery which just shifts the problem. Ultimately if we're hooking back up to the grid in any way it's a "it might happen" scenario, where the DNO no doubt has to cover themselves in case you either incorrectly configure or lie and put a bigger inverter in and wreck some network equipment.
