It was out for a few week then disappeared.
They were out of stock for a few weeks after the initial early batch but came back in to stock again later, you can still buy the 3100 now, its in stock.
They sold very well, good little CPU at the time.
Yeah I wonder how it would do with AMDs budget 6500XT?pairing it with such a high end system is stupid. see how it performs in a budget build then compare and come to a conclusion.
I've always hated this in reviews. No, you're not "showing the real difference by eliminating bottlenecks" - you're instead changing the entire performance landscape you operate under and then getting spurious results. If you had unlimited time it'd be nice to see a good variety of platforms and graphics cards and so on, but the real-world performance is going to be on a budget-appropriate motherboard and with matching GPU. If that results in the CPUs being tied then, well, the CPUs were tied. It also gives people a lot better ability to see where to spend money on a system - what would make a difference vs what only looks like it makes a difference cause we massaged the scenario to make an artificial load on one component.pairing it with such a high end system is stupid. see how it performs in a budget build then compare and come to a conclusion.
I also realise tech reviews are primarily about entertainment and engagement, neither of which is well served by finding no appreciable differences.
Yeah I wonder how it would do with AMDs budget 6500XT?![]()
£150 cpu with a £170 gpu is what people would probably use. Seems logical to compare at that level because that is what people would purchase. Then it comes down to total system cost which would be good consumer advice.
I'm pretty sure the 12100F would trounce the 5500 with a budget card like the 6500XT as the superior pcie gen 4.0 vs 3.0 comes into play for that card, also see the 12100F is only about 90 quid now.£150 cpu with a £170 gpu is what people would probably use. Seems logical to compare at that level because that is what people would purchase. Then it comes down to total system cost which would be good consumer advice.
Don't suppose you can remember where?That is correct, one review showed that a 12100f + 6500xt is faster in games than R5 5500 + 6500xt
