3070ti/Corsair RM 850
20 Nov 2020
Hi all I am so tired just now I hope one of you can clear my mind. Can I connect the 3070ti via the daisy cable. I planned to use two separate cables but I only have one pcie 6+2 on PSU. It has a 4+4 cpu socket x2 but both these are occupied for main board. I have several peripheral slots free?
Not sure if I can just run it off one cable or connect a second cable somewhere else on PSU, the shroud on meshify s restricts proper view of PSU. Any ideas would be appreciated. Thank you p.s checked online but can't get definete answer.
I think that you will not get a definite answer as its not an ideal thing to do. Even if it runs it might not be stable, as power spikes cause issues.
You should have more than than one pcie socket & cable, please can you tell us why you "planned to use two separate cables but I only have one pcie 6+2 on PSU" as we might be able to understand and help more. Hope this video might help, https://youtu.be/01T4la0YJ94
Hi thanks for reply I have two cables and plugged both into PSU and the card. When I switch on, the fans on card spin then turn off and board led indicates vga error?
