Hi intelligent people who hopefully can explain why this may occur.
I have been running four memory modules for over one and half years without problems at their rated 3600mhz speed. The system had been rock solid. The other day I switched out a GTX 1080 for a 3080Ti, then after a few days of greatness I realised my bios predated the Resizable BAR feature, so I updated the bios. The first problem I noticed was a laggy bios UI, then after setting things up (in bios) Windows then tried to repair itself. It booted, but I was getting lockups. I tested the system and it was corrupt and wouldn't accept a repair. I then went ahead and tested the memory in Memtestx86 from pen drive. It detected errors, so I tested the sticks individually (think I used B2) and they all passed (in XMP profile). I then started to test the DIMM slots only to discover both A1 and B1 won't run at XMP (they would just revert to JEDEC 2666 speed with 1.35v on the dram), whilst A2 and B2 will.
I then reverted to the bios I was using but the problem remained. I settled with XMP using two modules in A2 and B2 and everything was solid, but of course I wasn't happy. So, after a day or so of slightly unhappy gaming I tried another bios (one down but still with Resizable Bar features) and it flashed OK and the UI is as snappy as the old bios I was using. Same memory problem. I then did the obvious thing and changed the graphics card to something very weak, but again, the memory problem was still there.
Using one module in A1 I was able to mimick 3200mhz C16 manually and the system booted and held the speed (3600mhz c18 didn't). This is where I stopped because it's baffling me, since 3600 mhz c18 and 3200mhz c16 isn't all that different on balance.
* I also thoroughly cleared cmos throughout testing.
My specs:
R7 3700x - I don't OC it (no point) but I did use a tweaked PBO, which is currently disabled.
32gb Corsair Vengeance 3600mhz c18 (4x8 same brand and matching chips - worked for a long time together, but they're still two sets of 2xdual channels).
3080Ti (Gaming OC)
Gigabyte Aorus x570 Elite (rev 1.0) currently running F34 bios.
850w PSU
etc etc
The only things I can think of is the IMC or a fault developed on the board. The board has some warranty left, but the CPU doesn't. 32gb is needed for development work.
My specs:
3080Ti (Gaming OC)
850w PSU
etc etc
