Ground Loop issue after rebuild
9 Feb 2018
Over the last few days I have been tearing my hair out trying to chase down a ground loop that has manifested.
My original build was (only listing components that should be relevant)
Aorus X570 Pro Motherboard
Inno 3D GTX 1080
Sound Blaster AE-9
TP-Link Wifi-AC internal card.
EKWB Watercooling loop with EK Fans.
2 xCorsair simple red LED Fans
Corsair AX760i PSU
Phanteks Enthoo Pro Case.
Corsair K70 Keyboard
Logitech G502 Mouse
Sound System
Pioneer SC-LX72 AV Receiver
B&W Front and Center Speakers
Logitech satellites
REL T7/x Subwoofer
Everything was awesome. No issues at all.
Last week I bought a Lian Li O11D Evo Case a Seasonic GX-1000 PSU, some new corsair RGB fans.
Rebuild went smoothly however I now appear to have a ground loop in the system which is slightly noticeable on desktop when moving the mouse but becomes very loud when launching into a game to the point where you have to turn the sound up to drown it out.
So far I have tried, in order and all without success
Switched to a GTX780 GPU
Unplugged the Display Port cable
Switched back to the Corsair PSU
Removed the Sound Card
Removed the wifi card
Disconnected the Corsair RGB controller
Disconnected ALL the case cables (USB/Sound/RGB) except the switch connector
Disconnected all bar one logitech speaker from the Amp
As it stands my system consists of
Lian Li Case
Aorus Mobo
GTX1080
EKWB Watercooling Loop with two Corsair Fans (RGB not plugged in)
Corsair PSU
Rebuilding back in the Phanteks case is no longer possible as it was donated to another family member who was visiting at the start of the easter break - hindsight is a wonderful thing, never expected to encounter this!
So in my mind I've reduced the system down to a known good config, with the exception of the fans which I'm reluctant to unplug (along with the pump) in case of damage to the CPU but in researching this issue I've yet to find anything relating to fans being culprit.
In short - what the <long string of expletives> could possible be causing the ground loop and how can I eliminate it?
Any advice or suggestions for other steps I can take would be massively appreciated.
19 Jun 2009
I've no idea what's causing the noise issue, however I'm going to tell you something relating to grounding.
Cases are painted and this paint stops them being earthed correctly.
In this first picture I've sanded the PSU screw areas on my Silverstone FT-02 case, I've also not used the Seasonic painted screws and used regular silver screws.
I have also added HDD grounding scraps to my HDD's that are held in plastic anti-vibration, see second photo.
gYBeBhF6HlhIk_HQS0mu6qKSjLtEJXfn4TM-QtBpGH0z4Qp51JI1de24tT1Xhg6WY607vtoYokc9QO4_eIasA8RjfGndvvXwv8CxKWlhKiM6ldDjOPI-un7gv8XNwp95zxQFdwUBjU_n8QvgP7PWZqGksWPEUgdTA5RA7ATsAnBf9O14AuL3XWMBAjfHkNvAVrcf35XHuemWxmAiNxq4XvQh0GciaUHSC6XdEQqOUuPrI0IVR82LEdeeF31amu2Nng2xo4Bq3t8_fQMNqkKR1U0vXRNrpcEZtleV9OQAWsMxRRkaqsc5iUG_N0Hp8eLrNNLnOspDA5nvCcZtD5zeyzZwEQmt6svASM3dmjA_fLLWzdRvJ22hdi5tpqd5jML3uQePpWtfolG491N3MeTSdn4eAhtsehaO3w0zSbCq25DlbWKn-bwi1P0Y4D-hMiS1OtR8nkJ1DBlQA65fHo4kNzSIN5zyL5--vyPk62KgceAgFQez_XlctmdCl0YhZA_2pSQ4nYuc2FFCyLrdFVvJW0b8qT-3fgBIGth_NMr-SJNYKFGN9HdX4DrBryxD-efm8zd-xxndpS7VRQD3OQm296VBqee7WWbSZIiD1dQZztAVzRMhNBAkHEvu5MudJXuSGbBnKgisUiWYxviIjqNVGDnBdCVq7o-gcp7KBGP5ub7iB6i3kkhWGf7PDstmEQ-WubGlEqVO7rGn0nScuVGemungrKlgBVlF3bJl123GEHx9AVv2dNLq5c8IEYM=w1188-h890-no
AM-JKLX2aaq3rILyKcgA53u_5nwAOcH4T-Va3MHPqkfqw6wVwYoh0-jlkvC2uKBu0zeZrIRT1VR62bjH4VTvB9zwD9UpqQcDDgbfH8X1l8p6ojC-i1JBZnFA-apBQYxw4_MeRZljeP5msSXhsZp3_iAd3GEj=w1188-h890-no
Again no idea if these ideas will help but gives some ideas that could help.
OP
9 Feb 2018
Thanks for replying Jason,
I've currently got the PSU outside the case sat on a cardboard box so I think it would be fair to discount that?
As for Hard drives, I've got an m2 ssd plugged into one of the motherboard sockets and nothing else so no dice there either...
19 Jun 2009
The PSU should be installed to the case as the 4 screws that hold the PSU are the only case grounding. Having the PSU outside the case means no grounding.
You should also sand the paint from the PSU screw locations and use standard silver screws (not painted) to make the best grounding connection.
6 Jun 2008
Finland
For as long as pump is circulating coolant it's OK to have fans stopped temporarily.
It would take quite a few minutes for desktop load to saturate water's heat capacity.
(assuming you haven't disabled CPU power saving)
It's coolant flow whose stopping shoots temperature to thermal throttling limit in seconds.
21 Jul 2008
Outside the asylum
Are you sure it's really a ground loop (a hum at mainly 50Hz mains frequency)? It seems odd that a ground loop would come and go with mouse movement and disk/CPU activity. I once had a motherboard though where the on-board audio was susceptible to EMI, and mouse movements caused a buzzy/chirpy noise.
A few thoughts/questions that might help you get to the bottom of it:
Assuming the noise is via the AV amp and speakers, does it stop if you change input to something other than PC?
Are you using the AE-9 for headphones - do you hear the noise on them too?
Have you changed the way the audio is fed to the AV amp? E.g. optical before and analogue now, or AE-9 before and motherboard now? Have you tried optical?
Have you changed how the PC and AV amp are plugged in to the mains?
Good luck!
OP
9 Feb 2018
Fair enough - I routed the cables round the back, mounted the psu and used some plain screws with serated surface to grind the paint off down to bare metal (no sandpaper here at the mo).
Thanks for the reassurance - Disconnected the rad fans at the same time as remounting the psu.
Neither have sorted the issue :(
Good luck!
99% certain it's ground loop - not noticing any sound with disk activity (it's an nvme device plugged into the mobo after all), its faint but noticeable when moving the mouse and is at its loudest when the GPU kicks into gear once you get beyond the initial loading screens and rendered objects start appearing on screen. I have tested with two GPU's (GTX 780 & 1080), both produce the same.
This clip on youtube is pretty much identical to my issue - https://youtu.be/LtUB367g4Vo
To answer your questions - does it stop on input change? Yes
Am I using the AE-9 for headphones? No but when I had the front panel audio connected to mobo it did stop with a pair of Sennheiser HD569's plugged in. I have also tried plugging in my Harmon Kardon Go+Play speaker via 3.5mm cable while it was connected to its mains charger, no sign of the noise on there.
Have I changed the way the audio was being fed? QED RCA Interconnects for the fronts and 3.5mm to twin RCA for the other channels before and after. Not tried Optical as I want the EQ control that is only available through analogue. MIght dig out the optical cable that came with the card to test that in a bit.
Any change to mains setup? No, same cables same extension plug, same socket. Before my dinner I popped down to local trade store and got a socket tester, checked every socket on the extension and the mains and all read correct for wiring.
***edit***
optical cable located and tested with both on board and AE-9 audio - no noise detectable. but the sound quality is pants compared to the analogue AE-9 connection so the quest continues...
3 May 2012
Wetherspoons
I can see you have a wifi card and does your motherboard also have bluetooth?
If so, turn all wifi and bluetooth off completely on your PC and see if you still get the same. Long shot appreciated, but It'll take minutes so is worth a go.
There is reason behind this madness but its a long explanation lol.
OP
9 Feb 2018
Thanks for the suggestion, mobo only has wired networking and no BT capabilities. Wifi card (which does have BT) was removed from case during troubleshooting (see OP ;)) with no change in symptoms
21 Jul 2008
Outside the asylum
You might be right but I'd not rule out an electrical interference and/or a voltage regulation issue.
***edit***
Hmmm, puzzling (sorry, couldn't resist). When you say that you connected your HK battery(?) speaker, was that to the AE-9 analogue outputs or the onboard outputs? It would be good to narrow it down to being a problem with onboard and/or AE-9 analogue outputs, and whether the noise is present with / without your AV amp.
I just looked at the soundblaster AE-9 specs and it says you need to connect PCIe power if using the external ACM thingy. Any chance that's the problem?
19 Jun 2009
Some things to consider.
Is the sound card installed back in same slot it originally was.
If the card has PCIe power, is there anything sharing that cable, or does it have it's own dedicated cable going back to the PSU?
Is the dongle for your wireless mouse connected back into the same previous USB port?
Is the sound card earthed to the case, or again is the case painted around the cards metal bracket? (meaning sound card could not be grounded).
Have you checked the RCA connections connecting sound card to amp are clean? Do you have any electronic cleaner to clean the contracts? Poor contact on outer shielding can cause hum / interference?
Have you tried a different RCA cable?
How is your computer plugged into mains, are you using the same mains plug / setup as before? Have you changed anything like plugging the amp into a shared extension next to PC IEC?
If you run a graphics card load test, does the sound interference get worse?
Have you checked you have not accidently put the computer source volume low, forcing you to put amplifier gain up, highlighting interference that was always there but you never noticed before.
Have you moved your amplifier, or moved any PC cables close to it, that were not near it before.
OP
9 Feb 2018
Thanks for the reply wonko -
Tried it with both onboard and AE-9, no noise from the HK when connected to either source. Tried it on the center and surround channels too for good measure, still no noise from the HK.
I don't use the ACM module but I have got the card plugged into a dedicated 6 pin power cable. will disconnect it and see if it can run on socket power only.
JasonM...
"Is the sound card installed back in same slot it originally was?" Yes and i've tried it in the adjacent slot too
"If the card has PCIe power, is there anything sharing that cable, or does it have it's own dedicated cable going back to the PSU?" dedicated cable from the modular PSU
"Is the dongle for your wireless mouse connected back into the same previous USB port?" Its the wired version and is plugged into the original socket
"Is the sound card earthed to the case, or again is the case painted around the cards metal bracket? (meaning sound card could not be grounded)." Will have to check that (just got back from first round of golf in almost 2 years!)
"Have you checked the RCA connections connecting sound card to amp are clean? Do you have any electronic cleaner to clean the contracts? Poor contact on outer shielding can cause hum / interference?" I'll check them but I don't anticipate an issue, they are QED brand cables less than 6 months old, bought at same time as the AE-9.
"Have you tried a different RCA cable?" Yes
"How is your computer plugged into mains, are you using the same mains plug / setup as before? Have you changed anything like plugging the amp into a shared extension next to PC IEC?" No change at all to the mains setup (all devices into one "gang" plug, same socket config as before)
"If you run a graphics card load test, does the sound interference get worse?" Will get back to you on that after dinner
"Have you checked you have not accidently put the computer source volume low, forcing you to put amplifier gain up, highlighting interference that was always there but you never noticed before?" Definately no issues there
"Have you moved your amplifier, or moved any PC cables close to it, that were not near it before." Everything exactly as it was - simply unplugged from the Phanteks build, plugged into the Lian Li
26 Oct 2010
Leatherhead
I’ve just had the exact same situation with my AE9. Buzzing through the speakers (but not headphones) that scales with GPU activity. In my case it was triggered by upgrading my 3070 to a 3080.
Solved by plugging my active speakers into a different plug socket to the PSU. I’ve no idea why that fixed it but it was a suggested solution on a few different AV forums. Is your amp in the same socket as your PSU?
OP
9 Feb 2018
Thank god for working from home....logged off and ran to the utility room to grab an extension reel as the nearest socket is on the other side of the room.
With amp cranked to max the noise is there but you have to put your ear about 6 inches from the speakers to pick it up. At "normal" volume, sitting at the desk you wouldnt notice it.
I'm not gonna call fixed just yet as I now need to complete the build again with new PSU/fans etc. Was planning to see The Northman in cinema tonight but that might have to wait for another day following this revelation! Watch this space...
19 Jun 2009
I Solved by plugging my active speakers into a different plug socket to the PSU. I’ve no idea why that fixed it but it was a suggested solution on a few different AV forums
Glad your close to solving this, or at least improved most of the noise.
As yourself and Blue160 are beginning to understand, the mains quality / earthing is incredibility important to even PC audio.
The following is the wring setup in my office, people have flamed me on this forum about this, however everything you see is done to improve AV. Please notice the number of mains filters, and everything separate from each other.
AM-JKLXkPap6cbP42MQRAKYL3oEKfeBMTqXPqCUuYOtHJSP4y4xs01qlEu08FOhEZKlbCDjkHMyQYIJMj4_t3mmxyGvoJzWMysXOSzi2KL4eYEcqPfhhFt1UOn-ZpM-YCwUoRW9uobM56hUKpPv2yRMwodVu=w1528-h881-no
OP
9 Feb 2018
Got distracted by the football so took a bit longer than expected...
Rebuild just about complete. Just waiting on a splitter to give me a few more USB headers to control the fan lighting but otherwise everything is in and powered up.
Switching to the new PSU kicked the noise up a bit so I've upped the gain on the AE-9 a few db's so I can run the amp about 10% lower, I might bump it up further so long as it doesnt affect the sound quality. Fortunately you can't hear it on desktop but for now its at the point where I can live with it.
Busy for the next few evenings so hopefully I'll have a clear day on Sunday to open it back up and improve the cable management, especially the fan cables (6 RGB fans creates a LOT of mess). Longer term I'll be revamping my room at some point in the next few months, desk isnt big enough to handle the 42" OLED I've got my heart set on. That will require my amp to move closer to the other socket along with new extension cables and a few other tweaks too. With any luck that will further improve the situation but for now I guess we can call this done.
thanks again to everyone for your suggestions :)
OP
9 Feb 2018
@JasonM
I was typing up my last post and didnt realise you had also replied. Are you able to send me any links to the power cords you use please?
This has been a completely alien situation for me, if they are reasonably priced, or I can find something equivalent at a more palatable price I'll definately consider it.
I used to have an ASUS Xonar D2X until a few years ago, was gutted to get rid of it but the volume started to fluctuate a lot. Easily one of the best sound cards ever made though this AE-9 has really impressed me in the few months I've had it.
19 Jun 2009
Regarding the RA power cords I source them pre-owned from eBay, I own 9 currently and use them on various AV gear. I'm going to give you information about the power cords that is difficult to find..
There is different grades of RA power cables The basic cable is a Yello Power cables, and that is a good place to start, these can be sourced about £40 on eBay. There is also some called the 'Classic' and 'Reference' and there all different specs. The differences in all the cables is the dielectric, quality of the conductors, and number of twisted pairs, basically as you go up in quality the improvement they make also increases.
Some of the cables have Wattgate IEC connections on them, these make a better connection than a standard typically IEC, however my view it's the actual cable that makes the big gain.
The ones I've labelled 8TC there better then the Yellow Powers, there discontinued however they can be picked up on eBay for around £60-£100 depending on your luck.
And here is one on eBay now.
https://www.ebay.co.uk/itm/165429647696?_trkparms=amclksrc=ITM&aid=777008&algo=PERSONAL.TOPIC&ao=1&asc=20201018205123&meid=9523434d385e4e5097ec587686ddea2b&pid=101286&rk=1&rkt=1&mehot=none&itm=165429647696&pmt=0&noa=1&pg=2380057&algv=WatchlistVariantWithMLR&brand=Nordost&_trksid=p2380057.c101286.m47999&_trkparms=pageci:fab7492e-c0fc-11ec-8dc0-e238d23bb6e7|parentrq:49301b4c1800a0f310e4017dfffeceb4|iid:1
Now if you want to buy the new version of above it's called a Evolution 300, and it costs over £360 here. However I strongly recommend you buy all the cables pre-owned to save money.
https://www.russandrews.com/evolution-300-powerkord/
I'm sure the snake oil Police will jump on this thread now and tell me cables and mains conditioning is all nonsense, but just remember none of these people have ever tested these things to discover the truth for themselves.
And to attempt to give some basic idea of what they do. I'm running 2 active speakers, each have their own power transformers. If I run one speaker with a RA Yello Power mains cable, and the other with say a Dell / Free PC IEC, the speakers become unbalanced with the speaker using the RA power cable having more clarity.
When I used the Tacima mains conditioner and RA 8TC cable on my computer my Asus Essence card when to another level of detail, like it like having another sound card improvement. You have to take a leap of faith and trust what i'm saying.
The priority order is source first, then amplifiers. So other words you change the power cord for your computer first, then you upgrade the mains cables for your amplifier / active speakers.
The snake oil Police will also say the computer PSU will filter out any noise / interference, notice i'm using a Seasonic Titanium that's probably the best PSU on the market, so if the cables are helping that PSU then there going to help any computer PSU.
