I game and mine and haven’t had a crash or lock up so that’s good enough for meAre you mining on the CPU too? Then it wont show much instability as you are only working the card.
Stick CPU and card on mine and then do 130hrs........
see if that is stable
#goodluck
I’d love to get my hands on your samples.
Bet you say that to all the boys
Curve optimizer only works if you get a good cpu, if you lose the lottery your system will just crash when you try CO
I have been using CoreCycler to fine tune mine.
To start set a desired boost clock override and a global negative curve, run CoreCycler, it will tell you which cores error out, if they are all fine set a higher negative curve until one or more cores error.
Make a note of which cores error and go back in the BIOS, set per core negative curve, set all cores that passed to the curve value you had and the ones that error to the value where they passed, then test the remaining cores with a higher value negative curve. Keep doing that until you have all cores individually set.
https://www.overclock.net/threads/corecycler-tool-for-testing-curve-optimizer-settings.1777398/
Thanks man. I have started using CoreCycler instead of OCCT now. The interface is less modern but it did find an error running overnight so I reduced to a smaller offset on that core. At present I am testing at stock but I might switch to a +50mHz PBO Overdrive offset and retest afterwards. I am not sure it will make much of a difference though as I hardly saw a benefit at +200mHz (which was unstable).
Aslo, don't set higher PTT, TDC and EDC values on a 5800X, there is no reason a 5800X would use more than its stock values, for example PPT is 142 watt, that's the socket limit, if you need to set higher values than that for a 5800X something is set wrong, even at 4.9Ghz full bore R23 it shouldn't be pulling more power than that.
Something like a 5950X is different, effectively two 5800X's, one pulls 110 to 130 watts at 4.8Ghz in R23, double that but minus about 15 to 20 watts for the IO die for all core 4.8Ghz in R23 5950X, so around 220 watts. that's how you get that juicy 32K+ in R23. (2X a 5800X)
Bet you would…I’d love to get my hands on your samples.
At stock, my 5950x is getting scores of 23,000 on r23 without PBO. Is this normal? Ram is 4x8gb 3600mhz CAS 16-18-18-36. (multi core that is obviously)
Can be better. This 5900x scores 22,000 with tweaking so I'd look into PBO and CO.
This one is stable at - 30 on all cores with Curve Optimiser at and 155a EDC. Boosts to almost 5Ghz in games while staying fairly cool, the extra performance is noticeable.
Watch the video posted in the first post here. I didn't use that particular one but it's not so difficult.
Edit: it IS normal without tweaking.
