I was planning a new Intel 12th Gen build, as my 8 year X97 motherboard is starting to develop problems, so far 2 SATA ports have failed.
I was planning on going with a 12700K, the MSI Z690 Edge DDR4 motherboard and 32GB of DDR4 RAM (Kingston or Corsair), and re-use my existing GPU, GTX 1070, until the new GPU releases later this year.
Part of the reason to go with 12th Gen was that it had a PCIe Gen 5 slot and it was expected that the new generation of GPUs would be PCIe 5.0 but reading the rumours it looks like they will be PCIe 4.0.
Given that I am planning on using DDR4 and upgrade to DDR5 in a year or 2, once prices drop, and the quite serious bugs are sorted out, such as 4 DIMMs causing no POST issues as well as problems loading XMP 3.0, and it's possible that PCIe 5.0 may not be in use, GPU wise for possible another year, maybe two.
Would using previous generation parts make more sense, than diving straight into the latest generation, and using the saved money for a PCIe 5.0/DDR5 upgrade later?
If I went with older parts I would probably go the AMD route and use a Ryzen 5800X or 5900X, though if Intel a i7 10th Gen.
