Which overclock is better for gaming?
14 Jan 2013
Horsham
3800mhz 16-16-16-32
or
3600mhz 14-15-14-30
I'm on the X370 chipset using a 3900x with PBO enabled and everything else default.
Memory is samsung b die.
Either overclock seems to make no difference in games vs stock XMP 3200mhz 14-14-14-34 so I'm wondering if its even worth it, or if frequency vs timings makes a difference.
Are you changing the infinity fabric speed (Fclk) as well? If not then it's unlikely you will see that much difference
Depends on what the Fclk/Infinity Fabric divider is set to - it may be correct on Auto, but worth checking
Ideally the Infinity fabric should run at 1/2 the RAM speed. I.e. 1800Mhz for 3600Mhz. Anything above 3733 will by default use a different divider potentially reducing performance (unless set manually e.g. to 1900 for 3800Mhz RAM, which may require e.g. voltage tweaks for stability)
Its on Auto and just having looked at hwinfo64 the IF is at 1800mhz which is half the current speed I am running.
Any idea on differences between the two frequencies/timings in OP?
Thanks guys. Out of the options below which would you pick:
1. Set to XMP (3200mhz 14-14-14-34), leave default and live a happy life
2. Set to XMP, tighten timings to 14-13-13-26 and leave alone
3. Set to 3600mhz 14-15-14-30 for seemingly no difference and more voltage
4. Set to 3800mhz 16-16-16-32 for seemingly no difference and more voltage
Out of these choices 3. (3600 14-15-15) should be fastest. Could confirm in aida64 latency test.
But as you already found out, all 4 would be fairly similar. maybe geekbench could appreciate the difference.
Agreed. OP if you can measure your 1% lows, you'd probably see a difference with the RAM overclocked to 3600CL14-15-15.
I'm confused as to why you have both come out with 14-15-15 after I had said 14-15-14? I thought lower was better?
The second number in the timings (TCL) impacts your performance waaaay more.
When people say that they have CL14 and their running 14-16-16-36, it’s not really CL14.
14-14-14-36 is quicker than 14-15-14 -36.
Also, as your speed improves, your latency drops.
You are doing more per second, even if you’re doing it slightly slower.
3600 is also ideal as it runs the FCLK at 1800 in a 1:1 ratio with the ram.
