Best HPI check
26 Oct 2013
Leicester
Hi all,
Any recommendations for a single car HPI check? Just a basic one, car is at a BMW dealer but just want to be sure.
Thanks.
Total Car Check app on your phone will give you a quick vehicle check of whether there is outstanding finance etc.
If you want an actual HPI Check (with the £30k HPI Guarantee) then you'd need to use the actual https://hpicheck.com/ website for £19.99
As above though, an actual dealership should have no problems in showing you the HPI Check they have done (although obviously you aren't covered for any financial loss through it)
Hi all,
Thanks.
I couldn't say I know all the legalities etc, but when you are dealing with a proper BMW dealer, I think you can be pretty sure they won't be selling a car with finance on it. An HPI check is more necessary when it's a private sale and whoever is selling it could "disappear". The BMW dealer will have checked for finance before taking on the car. If there was a problem, it would be easy to take it up with them.
I like vcheck.
If you want one from the big two providers, HPI and Experian then the following is quit cheap.
Thanks guys. I am aware that BMW would do one, but just wanted to do a personal one for the sake of a few £
I went with the vcheck after @muon recommendation, thanks very much all
