Sony Trinitron CRT Service Menu help?
  • Thread starter Thread starter Zaf
  • Start date Start date
Zaf
Zaf
16 Jan 2003
Derbyshire
Hey guys, I’ve only recently realised this forum exists on OcUK :o
I’ve got a Sony Trinitron KV-21FV1U and I’ve used the service menu to adjust the HPOS and VPOS, but does anyone know if any of the other settings allow you to rotate?
The top right corner needs rotating down
Adjusting The Picture Rotation
(only for KV-21FV1U)
Because of the earth’s magnetism, the picture may be slant. In this case, you can
correct the pictures slant by using the option “Picture Rotation” in the “Set Up”
menu.
To do that: by using the menu system and after selecting the option, press . Then
press or to correct any slant of the picture between -5 and +5 and finally pressOK
to store.
Any good?
From here :https://pdf.notice-facile.com/file/2019/11/5ddacfbd43930.pdf
Ah don't miss those days - you'd just get the horizontal and vertical alignment right, finessed the rotation only to find the picture was slightly skewed or the top/bottom of the picture tapering to different widths, etc. etc.
