Something I was idly thinking about yesterday.
Let's say you were given a wish, which is that you can relive one year of your life with all the same events, all the same responses from people etc, but you will be in your 2022 brain. Nothing will change, and you cannot screw anything up, but your life will be shortened by ten years. When the year is up, you will back in May 2023 and can carry on pretty much as you left off.
Would you do it? You have several options though, if you want to consider it...
Easy mode: You don't take the wish. Nothing changes.
Normal mode: You get to relive the year of your choice. It can be any 12 month span [e.g. June 2012 to May 2013]. You can't mess anything up. People will still react to you as they did then even if you try to mess things up. Your life is shortened by ten years.
Hard mode: You get to choose any year, but it must be Jan-Dec only. You can't mess anything up. Your life is shortened by seven years.
Nightmare mode: You get to choose any year, but Jan-Dec only. You can mess things up and events can change if you make the wrong choices. Your life is shortened by five years.
Chaos mode: As Nightmare mode but when you return in May 2023 no-one will have missed you or remember you and everyone will have moved on. Your life is shortened by three years.
So, GD, which is it to be?
The only thing waiting for you in May 2023 will be more Windows updates
