Hello all, long time since I have been on here.
Currently running:
Ryzen 1600
ROG Strix B350
16GB 3200mhz
RX 480 8GB
Superflower 550w Platinum
Looking to pass this onto the children as a gaming machine to replace their 2500K running a 1050ti (didn't see a reason for either of us to upgrade during shortage crisis).
Question 1 is whether it is worth buying a second hand 3600x to drop in for them (£150?) or to buy MSI Tomahawk B450 Max II for £60 and drop in a 5600 for £180 which I think makes more sense. Then after ARC/4x00/7x00 releases come out, upgrade their 1050ti. It is only really going to be used for YouTube and gaming at 1080p.
Question 2 is for me. Seeing as I am donating my machine, I will need another one. Would
getting the MSI Tomahawk B450 Max II above paired with R7 5700x and 32GB 3600mhz ram be a waste at this juncture (£60+ £270+ £100 =£430) and would getting the MSI Gaming Plus B550 for another £55 make a huge difference?
Should I rather wait for Ryzen 4 (6000 series)?
I do occasionally game (mostly War thunder, Assassin's Creed series) but the PC is on 12-14 hours daily for trading (so mostly at idle) and I am more concerned with power usage therefore AMD makes more sense than 12600/12700 although that has a marginal upgrade path.
Thanks
NB
Currently running:
Ryzen 1600
ROG Strix B350
16GB 3200mhz
RX 480 8GB
Thanks
NB
