New to PC Gaming, what can i upgrade?
8 May 2022
St Helens
Hi I'm new to pc...I got a prebuild and looking to upgrade if it improves my experience.
Here are my specs:
Processor:
AMD Ryzen 5 5600X (6 Cores up to 4.6GHz, 32MB Cache)
Memory:
16GB Corsair Vengeance LPX 3200MHz (2x8GB)
Hard Drive:
Seagate FireCuda 510 1TB M.2 2280 NVMe & Seagate 2TB BarraCuda
GPU:
NVIDIA GeForce RTX 3070 8GB *
Power Supply:
Corsair 750W TX750M
Motherboard:
ASUS PRIME B550M-K
Cooling:
Coolermaster Hyper 212 RGB
Not really worth upgrading anything there. I can't imagine it struggling, unless you're playing games at 4K or doing something demanding like rendering?
Take it this is for gaming?
Your RTX 3070 is a good current gen GPU ideal for gaming up to 1440P, and the 5600X is a good cpu also. PSU gold rated and great for a 3070. As above, looks well balanced to me
Not really going to effect anything, but you could add a 2nd nvme for your games storage rather than keeping everything on the HDD. As more games implement Directstorage into their games you'll need to play from a gen3 nvme or higher to utilize it. ATM, you could just transfer the game to your primary drive which will work also so adding another nvme not essential at all.
I included a couple of 2tb below. The SN750 is gen 3, the SN850 is gen4. Both on offer atm. Below that 2 gen4 1tb drives. the gen3 sn750 is £99.99 so for the exta £10 might as well go gen4 if going 1tb route
just stressing again, not essential but nice to have...
My basket at OcUK:
Total: £630.66 (includes delivery: £8.70)​
Here are my specs:
Processor:
Memory:
Hard Drive:
GPU:
Power Supply:
Corsair 750W TX750M
Motherboard:
ASUS PRIME B550M-K
Cooling:
That’s a solid build right there so unless it’s not giving you 60fps or making you unhappy in any way, keep it as is.
Itchy upgrade trigger finger?
I have almost the same specs, no need to add to build apart from what others have said, a second storage NVME-if you have a spare slot. Unless you plan on 4K gaming, then you would have to spend about £900.00 for an RTX 3080.
At 1080P or 1440p, should perform fine.
Maybe double the RAM? Or get 3600Mhz 32 Gb kit?
My basket at OcUK:
Total: £137.69 (includes delivery: £8.70)​
