- 9 May 2022
- London
Hi
My current PC is an i7 4790k and a 1080. I am looking for a hefty upgrade on this. The PC will be used purely for gaming on a 1440p screen although I might perhaps upgrade to a 4k monitor in the future.
I have built PCs before but my problem is I am not technical enough to know the difference between all the different CPU's etc. For example I don't want to spend an extra £100-200 on a CPU that is on paper really quick but actually offers no real benefits compared to a cheaper CPU when it comes to gaming.
The only requirements that I have are as follows:
- The graphics card needs to be a Nvidia 3080 or better (Only interested in Nvidia GPUs)
- The CPU id rather be Intel but that's only because I have never used AMD CPU's, if there is an AMD equivalent which is cheaper and gives me the same or better performance then im open to going down that route.
- 32gb Ram (for Microsoft flight simulator). I have no idea whether DDR5 is worth it or not ?
- 1TB SSD drive. If NVME drives are notably quicker than normal SSD's then id be interested in that, if not just a normal SSD is fine.
Then id need a power supply for it all, cpu cooler and a case ? Anything else ? I don't mind spending a bit extra to make the PC visually pleasing as well, whether that be on the case, fans, RGB lighting etc
Any help would be massively appreciated.
