2060 on sale
10 May 2022
UK
This is on sale and the same price as a 6gb card.
I have never bought and placed a new GPU into a pc before, im mostly consoles. I dont know if this will physically fit into my current PC, i have a Acer Nitro N50-600 and when I have opened the case theres very little room. Putting more Ram in was a pain. I also hear how they are a pain to upgrade due to motherboard limitations
I think this is the same cooler on the 6GB version?
They used a tape measure and it is 23.5 cm, which matches what Palit say on their website for the 12GB model.
Do you know what the PSU is in the Nitro? What are you upgrading from?
It is possible to buy 3050 and 3060 cards that are more compact, like the Aero ITX and Phoenix models.
i think the palit storm x 3060 is under 20cm, but more pricey.
you have 14 day return if it doesnt fit btw
fitting is so easy, youtube if not 100%.
