That won’t take long surely?im saving for my reduction of my manhood.
it is in general a bad idea overpaying mortgage, investing on a tracker fund will give far better returns.I guess what surprised me, the way people recommend it as a good investment, I expected it to work a little like compound interest, so if I pay a bunch off, the overall amount I would be paying back would drop significantly as I'd pay less in interest... but no, it just comes down by the amount I pay early...
Paying into an ISA seems like a better idea for a long term (15+ year) plan then (aside how the market is at the moment!)
Don't use the 'monthly amount' field, use the interest rate field with your mortgage interest rate. It'll display the right figures then. Probably a bug in the calculator.Someone mentioned overpaying the mortgage. Having a play with this calculator, I don't really get it. I threw in some numbers - £200k left over 15 years, paying £1,100 a month. One off overpayment of £40k and it says "Overpaying would save you £-695 in interest alone"? For one, that's a double negative and saying I would pay more? Secondly, only £695?!?! Investing £40k would get me a lot more than that over 15 years... lastly, it says I would pay off about 3 years early, well that's simply £40k's worth of repayments? Is the calculator just bad?
Yeah I get it in terms of making the most of your money. I can’t shake that warm feeling of getting rid of the mortgage though (when it eventually happens).it is in general a bad idea overpaying mortgage, investing on a tracker fund will give far better returns.
The long term average of most index funds is about 7%, unless your mortgage rate is close to that you are just throwing money away
What's the plan if markets don't recover and your ISA drops in value by the time your mortgage fix ends, and the mortgage rates rise substantially (in theory)? Would you then empty your S&S ISA in to your mortgage if the rate went above 7%?it is in general a bad idea overpaying mortgage, investing on a tracker fund will give far better returns.
depends on a few factors. Markets usually recover within about 6-12 months snd the chancesnof 7% mortgage rates is quite rare. Moreover, the markets might be temporarily fown on their previous peak but of ypu hsve invested for some years it is likely you are already financial ahead, so you should think nore in terms of pro-rated returns than the immediate market decline.What's the plan if markets don't recover and your ISA drops in value by the time your mortgage fix ends, and the mortgage rates rise substantially (in theory)? Would you then empty your S&S ISA in to your mortgage if the rate went above 7%?
Don't know about @Worthy, but for me I don't care about the debt: I'm just looking forward to not having to pay £1200 a month any more when the mortgage clears! That's going to be ******* sweet!if you don't like the feeling of devt then renting is the way to go IMO.
No chance. When I’m retired I want the roof over my head to be bought and paid for. I don’t want to have to worry about paying for someone else‘s mortgage out of my pension.if you don't like the feeling of devt then renting is the way to go IMO.
I will likely die with a high 6 figure (chf) mortgage. literally zero point in paying anything more than the minimum, and even if i wanted to there is no easy way
Well if its free I'm more than willing to give a few inches away for free to even it outIn your case that's known as gender reassignment, the NHS should cover it.
Might save you a few quid.
Well, no I don’t have the same attitude for those because I don’t own an oil field/processing station so I have to pay for those. I’m not sure what point it is that you’re trying to make here. Rent is an ongoing cost forever, a mortgage isn’t. I think the place would have to fall down for maintenance costs to be the same as my mortgage, and depreciation in the housing market, has that ever happened over a long enough period? Ignoring the fact that dips in the market are only an issue if you want to sell, which I won’t.Do you have the same attitude for things like utility bills, insurance, food? Going to live off subsistence farming? Rental and mortgages are no different to any other cost. Owning a house then means you are liable on maintain and upkeep costs , as well as depreciation risks. This is why it is quite common to sell houses when you retire so living costs can be better predicted.
True, but there's a much greater risk. I used the mortgage calculator linked above and a compound interest calculator to compare.it is in general a bad idea overpaying mortgage, investing on a tracker fund will give far better returns.
Doing both, I'm not a higher tax bracket earner so the salary sacrifice is of less benefit? From from what i read a LISA was a good idea, probably wouldn't want to listen to me on pension advice though.![]()
