Stupid question time...
On the right side here you can see the heatsink curls up towards the backplate. It is not an optical illusion or perspective, the tip of the heatsink is close to 1 cm nearer the backplate than the middle is. Is it meant to be like this, or is it intended to be straight?
Put it in the PC, works fine. Seems to run a bit warmer than reviews implied... not sure if this might be why? It occurs that the rear fan will not be blowing perpendicular through the fins.
Appreciate advice.
Appreciate advice.
