what software for screen record
19 Mar 2011
As above just left ryzen/amd and relive software and built a new intel/nvidia system i used to use shadowplay in the past.
Those of you who do record gameplay and desktop what software do you use these days is obs still a go to product? i am not so much after live streaming i just need to record gameplay in the back ground
thanks
thanks
Windows 10 has built in recording software Windows Key+G. Might be enough?
If you have an nVidia GPU ShadowPlay is still the best for easy to use, low performance impact, video capture from games. Otherwise the next step from there is still OBS.
I'm using a mix of Windows and OBS. Windows to save the last 30 seconds, and OBS if I want to do a full recording. Shadowplay also works but I didn't want the entire GFE bloat.
