We bought our place last June and are about to start a loft conversion and kitchen renovation (amongst other less dramatic bits like replastering and decorating pretty much everywhere!). It's a small 2 bed terraced house, we'll be getting a new master bedroom up in the loft.
Our Sky router is in the lounge, right at the front of the house.
The study is the second bedroom at the back of the house, wifi is already flakey in here as it's furthest away from the router, so I'm using Devolo powerline adapters which work fine.
No wifi reaches to the garden.
I'd like to get ethernet up to the study obviously, and extend the wifi so that it reaches the loft and garden. My idea (in laymans terms) is to plug in an AP/extender into the new ethernet in the study, as that is a nice midpoint between the garden and loft room and could probably service them both. Question is, what sort of kit should I be looking at? I'm a very basic user but I'm guessing will need a switch somewhere, as I guess I'll need 3-4 ethernet points in the study eventually (home PC, 2x work laptops, AP, maybe Sky mini?). I only have one port free on the Sky router as it is. Would you put the switch down with the router and run 3-4 ethernets up to the study? Or run one up and have a switch in the study?
I guess I should also run ethernet up to the loft in case the AP in the study doesn't work well, or just generally for futureproofing (e.g. our neighbours use their loft as a study not a bedroom).
So, running the ethernet is fairly straightforward (just the question of where to put a switch?), but how would you sort the wifi? I can't spend a fortune, mesh sounds good but I'm not sure it's worth it here. I don't mind a separate SSID if that's how it has to be with an AP/extender.
Thanks.
I guess I should also run ethernet up to the loft in case the AP in the study doesn't work well, or just generally for futureproofing (e.g. our neighbours use their loft as a study not a bedroom).So, running the ethernet is fairly straightforward (just the question of where to put a switch?), but how would you sort the wifi? I can't spend a fortune, mesh sounds good but I'm not sure it's worth it here. I don't mind a separate SSID if that's how it has to be with an AP/extender.
Thanks.
). I'm sure when I asked him he was on about throwing the ethernet over the roof to get to the loft (my words, not his) which I thought was a bit odd. It's a terraced house, so no external walls... Would they ever use the chimney? We won't be installing a fire, only surrounds for aesthetics... just a thought.
If you can get them to pull it back and re-run it in the loft/floor space I would... To appease my own OCD and helps with kerb appeal lol. Makes so much sense to do it now if you're in the middle of converting the loft and floors up etc.
