Yeah but at least all of our politicians live well and don't have to worry.Can see the pound tumbling again today against the US Dollar. Even higher energy and food prices ahead. Oh dear.
I assumed he may mean the crap pre-heat stuff which otherwise keeps their onboard small tank ready heated if people do make instantaneous demands (whilst no one is in the house)Why would you turn the boiler on and off?
We had to build new homes for foreign investors that will never live in them. Help jack up home prices by getting ride of storage.Interesting read from Ed on the UK's current gas situation
The surreal, but also real, problem of Britain's gas glut
The UK is drowning in gas - but consumers will get little or no relief from these very low prices, writes Ed Conwaynews.sky.com
The political decision to close a lot of the UK's LNG storage is now looking REALLY stupid
Didn't know how positive the UK's capability to import LNG was vs most of Europe.
Wonder if all this will actually translate into sustained reductions of UK Natural Gas futures pricing.....
It will make a massive difference to me, fixed DD assumes I will use much more in winter so I end up with a very high credit balance, at one point late last year I had over a £1000 in credit, and was £900 in credit in December.
I will be changing to variable after an issue is resolved probably before start of June.
It clearly doesnt just divide the previous year total by 12 otherwise we wouldnt have people overpaying by so much. We have had people in this very thread been quoted an annual cost, and then with a DD set much higher. The companies are currently been investigated for it. Also it isnt actually fixed either, the amount constantly gets adjusted after every reading. So there is an algorithm at play. Part of the confusion is people actually think its fixed when its not.
I never proposed fixed DD goes away so would have no issue with it been offered.
But I do take issue that they both equal cost. Fixed DD you pay in advance so you out of pocket, and in addition its algorithms are not perfect leading to some customers been in credit for long periods, even over winter, my theory as to why that happens to some people is maybe the algorithms assume the winter bill will be much higher and for those it isnt, they end up over paying, there is also the potential some suppliers are deliberately making it too high to build cashflow (which is currently been investigated by ofgem and ministers). I know e.g. my winter bill is barely any higher than my summer bills which I think throws the fixed DD algorithm completely off. I do think it would need to be part of the explanation that fixed DD you may end up paying more, but smooths the adjustments made to payments in colder months.
Bear in mind fixed DD does not assure DD's dont change, I am still on fixed DD and it changes daily the amount, plus as we know it changes when SVR cap changes. If we keep telling peopled fixed DD is actually fixed they going to be in for a shock this October, then the January after and so on (as from October SVR is changing every 3 months).
the (negligent) sky article implies current govt are responsible - but issues was known in 2011, france having 90 days storage and us a few weeks didn't happen overnightThe political decision to close a lot of the UK's LNG storage is now looking REALLY stupid![]()
This means for the maximum annual power consumption of different device classes with a daily standby duration of 22 hours:
- Device without information display (0.5 W): approx. 4 kWh
- Device with information display (1 W): approx. 8 kWh
- Device with high network availability (8 W): approx. 64 kWh
Not sure why you are blaming the algorithm here - you've obviously not set your DD correctly.
I dont set my DD, its set by Octopus. Dispite people defending it and making claims it works perfect, it doesmt, you only need to search posts on here by multiple people that clearly show their DD is not set to their annual usage. In addition a point you ignored "the providers are currently been investigated for the practice of setting DD's higher than usage"As @touch says, the calculation isn't complex - it's just your annual usage/12. Before April, my DD amount didn't change in 12 months, and has perfectly covered my annual usage to within £12, because I set it to exactly the right amount to cover my usage.
Obviously if you've just moved into a new property you may not have an accurate idea of what your usage is going to be, but you clearly aren't in that position since you're making such a fuss about it.
The algorithm will be based on averaging hundreds (if not thousands) of data points from existing customers, so obviously it's not going to accurately reflect someone with atypical usage such as yourself, but like I said, if you know your usage then just set the DD to a figure you know will cover your usage. If you can't be bothered to do that then don't complain you aren't paying the right amount.
Except you don't. I don't understand why this is such a difficult concept to grasp. If you use 5,000 units of electricity @ 30p and 10,000 units of gas @ 10p, then you pay for 5,000 units of electricity @ 30p and 10,000 units of gas @ 10p. It doesn't matter* whether you pay by fixed monthly DD, quarterly DD, pay in arrears when you receive the bill, send a cheque to the supplier, deliver a truckload of 1p coins in person or barter for a herd of goats, you still only pay for 5,000 units of electricity @ 30p and 10,000 units of gas @ 10p. You may end up with a credit on your account if the DD is set too high, but that money is still yours, it doesn't just disappear, and you can either request a refund or reduce your DD to below your usage so that the credit gradually reduces. Regardless, you still end up paying the same amount.
* we'll ignore any discounts given for paying by DD for the sake of simplicity.
I know and what this means the customers who fall outside of normal use patterns may get an inaccurate predicted usage and hence a DD thats not set to the right level.
Your provider lets you set it and then doesnt change it by themselves?This is why I made it clear in my post that it's simple "if you know how much you use over a year".
My fixed DD is accurate because it's not set based on their predicted usage, it's set based on my accurate historical data. I know exactly how much i've used over the past few years. If you're taking their predicted usage figure then it's not surprising your DD value wasn't set correctly.
Yes, I'm with Octopus too.Your provider lets you set it and then doesnt change it by themselves?
Octopus are predicting I will use £3800 of electric this year (and £180 gas) lol, noticed it on my most recent bill, thankfully the DD hasnt been adjusted for that amount. The actual bill based on automated smart meter readings was circa £30 for 18 days.
I'm on the variable rate and when the prices changed recently I calculated that my monthly cost should increase from £80 to £140. Octopus made a similar calculation and put my DD up to £146 but I was able to change this to £140 myself.
Some suppliers (BG for example) don't allow you to reduce your DD though, they only allow you to increase it. After this winter I was £200 in credit on my gas account.
Edit: found where to see the predicted cost in my account. Octopus predict £1743 (which is where the £146 DD must have come from) and my own calculations predict £1680. I've been with Octopus for 2 years and submit a meter reading every month.
For me right now my actual cost is way below my DD, but my DD is also way below their predicted cost, so the DD is in no mans land. After an issue is resolved this week, I am switching to variable DD to get rid of the mess.![]()
Yep tried last year when I noticed my credit balance was so high, it was accepted but I was given a warning it will be increased if they believe it set so low, I then noticed the normal amount got taken out my bank a couple of weeks later, and seen it was adjusted back on my account, I havent tried to reduce it again this year.Have you tried changing it?
Log in to your account and on the dashboard page below where it shows your balance and monthly payment there's a link to "Change my payments". That's how I did it and it let me set my DD to the right amount.
That's a very useful visualisation, is there a more up to date version out there? I know the Winter 22 level hasn't been set yet but would be interesting to see.Just responding to the point about Ofgem not reducing the price cap.
The price cap is currently set in April and October and is based on the previous 6 month wholesale price. Historically Ofgem have reduced it when the wholesale price has dropped - see this chart below; the black horizontal lines show the price caps.
That's strange, because I'm also with Octopus, and I have full control over my DD amount. Like I said, I set it to the correct amount just over a year ago, and until April it hasn't changed at all. I manually updated it in April to take into account the increase on costs as my fixed gas tariff ran out. Octopus themselves haven't updated it or had any communication with me about changing it in the past 3 years since I joined them.I dont set my DD, its set by Octopus. Dispite people defending it and making claims it works perfect, it doesmt, you only need to search posts on here by multiple people that clearly show their DD is not set to their annual usage. In addition a point you ignored "the providers are currently been investigated for the practice of setting DD's higher than usage"
I do grasp that, I said as much in my post. I also said that if you know your usage isn't typical (as you do) then adjust your DD accordingly.I know and what this means the customers who fall outside of normal use patterns may get an inaccurate predicted usage and hence a DD thats not set to the right level.
The bit that you dont seem to grasp is that you assume the automatic DD on fixed DD is accurate, what is this assumption based on?
You can disagree all you want, that doesn't change the fact you are wrong.Disagree for the reasons I said above.
Thank you for agreeing with me and proving my point, as you say yourself, you have been IN CREDIT. The money is still there, it is still yours, and you can withdraw it or use it towards your bills if you want. If what you were saying was true and that you were paying more for your energy, then that money wouldn't be showing as a credit on your account, it would have been swallowed up by increased energy costs because for some inexplicable reason you would have been paying higher unit rates than your tariff.If your statement was true than why have I been in credit for my entire time on Octopus which is multiple years with the credit balance slowly building over time until it peaked at over £1000 late autumn, and was £900 in the most recent winter. That simply should not be happening if your statement was true. As I said before I think the algorithm breaks when winter usage is less than expected, many people use an extreme amount of energy in winter, whilst I dont. So Octopus build up my balance anticipating me to use it in the Winter, I dont and hence the problem.
Also what is your answer to people getting statements such as predicted annual cost £2000, monthly DD set to £300, how does 12 x £300 = £2000?
I just checked my historical bills.
For 2021 I was billed a total of £813.69 gas+electric including SC and VAT.
My DD's were as follows 78,81,83,83,84,86,86,86,85,89,91,93 total £1025.
I was on a fixed deal until October, last 3 months SVR. So the DD's still moved around on fixed pricing. I remember one month reducing the DD massively, but then it was auto increased again on the payment day.
I expect in 2020 which had lower prices right through the year the gap was bigger.
i expect you will come back claiming this doesnt happen, so will leave it here, but if you search the dozens of pages on this thread the other energy threads you will find reports of people with over inflated DD's compared to their annual usage, and there is others aside from me who have a credit balance all year round.
