- 25 Oct 2005
Hi All,
I’m having some electrical work carried out next week which will involve running electrical power through the loft, down the side of the house, underground for ~5m and then into the garage.
Since the electrician is going to be doing this and digging channels for the power cables, I was thinking of using this as an opportunity to run cat6 cable from the loft into the garage, as that’s what I wil need in 3-6 months time.
Given that the cable will be buried and travel alongside mains cable, what cable should I use? I’d probably need 30 meters or so allowing for leeway.
Or is it a bad idea and I should just run the cat cable later and separate from the power?
Cheers,
Mike
Cheers,
Mike
