Sandisk Ultrafit USB sticks Fake ?
Underboss
20 Oct 2002
Oxfordshire / Bucks
i bought a 64Gb ultra fit sandisk USB Stick a few years ago
recently i bought another one, but a 32Gb , and im wondering if its fake
i am careful where i buy USB and memory cards from, like i will never buy from unknown 3rd party sellers, ebay etc
here's a photo of the 2 side by side, the black one is 32Gb, but it is not mentioned on it anywhere, only part of the name as 32G
It looks similar to the one listed on WD site, I'm not too sure how else you'd verify. Any perf tests done? - normally that's the easiest way to tell if it's fake.
I'm certain I have 2 identical ones. I'll check tomorrow. Easy check is to transfer a large file over and see if it dies at a gig or two.
Certainly looks like a genuine ultrafit model. Best bet could be to try and register it with the serial number. Not aware of any WD or Sandisk option to verify a product other than just registering it.
I would assume if it's a duplicate/fake serial, their system would say as much.
ill try that
thanks
Do a google search plenty of free software that tests USB sticks to help tell you a) whether they are genuine and b) what their actual capacity is.
I bought the 2TB USB stick off of Facebook that kept being advertised all over the site just because I was curious to find out what they were actually passing off. Turned out it was 256mb stick after using a USB Stick Test Tool.
Surely Windows explorer will tell you the size anyway?
There are tools to frig it, so Windows will report 2TB but actual storage will be like, 128mb. That's why I suggested to check authenticity by trying to write 30gigs worth of data to it.
There is no other benefit in "being fake".
Use a tool such as H2testw to check the capacity by actually filling it with data. I once bought a seemingly genuine SD card in proper packaging from a well-known store and found it was fake with this tool.
Pretty futile to trust marketing in such place.
H2TESTW Result :
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 15.3 MByte/s
Reading speed: 125 MByte/s
H2testw v1.4
That's pretty much normal results for toward lower end USB sticks:
Read speeds are easy to achieve, writes suck for actually filling that modern capacity.
