Good day folks! I'm after some assistance if possible please.
We've currently got a BT Smart Hub 2 that for the most part works fine, but the distance it needs to cover leaves some areas a bit lacking. Here's the useful info:
Grateful for any recommendations based on the above. A friend just kept yelling UBIQUITI at me, which you're welcome to do also!
I'm just not sure if my setup requires it.
Happy to answer any questions that the above doesn't provide, and take on any knowledge you'd like to pass along. Thanks!
- Distance between Superhub and furthest point that needs wifi is 14m away (2 brick walls, 2 plasterboard walls in between
- We have an ethernet connection between the router and my PC, which is in the middle of the two points listed above
- We've got an MT992 that could be paired with a separate router if that's a good option.
- We're open to a mesh setup and turning the Superhub wifi off altogether.
- 8 Alexa devices
- 2-3 bulbs per echo
- A few wifi 6 devices around the house, phones, laptop, console
- Couple of smart TVs
I'm just not sure if my setup requires it.Happy to answer any questions that the above doesn't provide, and take on any knowledge you'd like to pass along. Thanks!
