Best 5G LTE Router
Do you have another router? Plug it into another router and, if it’s stuck in CAP mode it will take an IP address from the other router and you can factory reset it.
If it’s stuck in NETInstall mode then you’ll need to download the NETInstall tool from Mikrotik’s website and reset it from that.
Hi got it working now thanks, needed the routerOS reslashed...
What is the best Mode to use i am using LTE AP Dual at moment and for some reason the router stops assigning IP addresses after some time and i have to use static IP to get connection. back....i have other routers connected via Ethernet, could this be the problem Mabe i need to use bridge mode sorry i am totally new to Mikrotec routers and its a little over my head..
I’m glad you got it running. I’m guessing you had to use the NETInstall tool?
Can you post up a diagram of what you have please because this is starting to sound quite complicated.
Thanks for the help, i had a fault on my billion router I was using as an Ethernet switch for my CCTV/IP-PBX when i connect the billion to my network everything goes down i have ordered a new simple switch and should be delivered tonight this should solve the problem....
