Backup tool for dual boot restore
23 Jan 2008
Hello,
I usually use Clonzilla for full disk backup and restore but unfortunately it won't do what I need to do in this instance.
I have two full disk backups of a tablet, one Windows and one Android, I'd like to turn the tablet into dual boot without having to install both OSs from scratch.
It initially came as dual boot and the target SSD has enough space for both.
Is there a free backup tool that would allow me to backup and restore offline via USB boot drive with the ability to specify which partitions to restore to and without overwriting all other existing partitions on the target drive?
Thanks
Thanks very much for that, have used Reflect in the past but didn't know it could be booted from a USB drive.
Will give it a try.
Cheers.
Will give it a try.
Cheers.
Yes can use it from usb
Can also use it as a pre boot environment
Ie if you have an operating system/systems installed
Then you can have macrium as a boot choice
Alongside windows
Assuming that's in the free version
Thanks again for the info.
Not had time to try it yet, spent all my free time this weekend
trying to install Androidx86 onto the tablet (partly successfully)
just to run an app to upgrade the firmware
on a set of wireless earphones.
Turns out the app doesn't support the ones I have yet. :rolleyes:
Cheers
