Caporegime
- 13 May 2003
- Warwickshire
Hi all
Ctrl D minimises all windows / shows the desktop. If you then do almost anything else apart from press Ctrl D again, it doesn't maximise / restore all windows.
Same with Win-M / Win-Shift-M. It works as in instant toggle, but if you minimise all then go to settings, or a game, or something, I can't then restore all windows without having to click each one individually.
Is there a Windows shortcut that will just maximise or restore all open program windows? Seems simple and I can't believe this isn't integrated into Windows, but I can't find anything.
