Budget Small form factor gaming / video PC build
6 Jun 2005
Plymouth / Cambridge
Hi All,
A family member wants a new PC on a budget to play games and do video editing, budget around £1000. can anyone recommend a build that would fit the NR200P , Tempted to suggest the MAX as a starting point but water cooling is not 100% needed.
i think a small form factor would be best for them so it does not take up much room. Nvidia card is a must though but the rest is optional.
Thanks
P
Intel (use the stock cooler)
My basket at OcUK:
Total: £1,021.19 (includes delivery: £12.30)​
AMD (use stock cooler)
My basket at OcUK:
Total: £1,025.18 (includes delivery: £12.30)​
Updated due to errors.
@dfour
AMD build Micro atx motherboard in a itx case.
The 5500 isnt that good chip the 5600 is superior close to the 12400 and supports pcie4.
Good catch, my bad. :(
I was trying to stay below his budget and the extra £40 for the 5600 blows his budget but with the only other itx below £170 its only £12 over budget. My only worry is about the quality of hte cheapo gigabyte boards. Never been that good in my experience and the next level up is £170+
My basket at OcUK:
Total: £366.04 (includes delivery: £11.10)​
Makes a better case to buy Intel this round.
My basket at OcUK:
Appreciate your argument, do you have something to put on the table for Ethereum mining. I don't know anything about RIG building, but I want to start mining as a side hassle. My starting budget is £4000. May increase easily up to £8000 if required
My basket at OcUK:
My basket at OcUK:
that is a pretty detailed budget you gave and it is very helpful , thank you so much for sharing
