Drilling into 6mm aluminium
14 Apr 2009
Cheshire
I need to drill a series of holes, symmetrically, into 5 or 6mm aluminium. 2 on one side, 2 on the other.
Ideally I need a pillar drill I guess.
Any idea where I could go to get this done for me?
I have a drill and a Dremel, I guess I could buy a pillar unit for them, or maybe spend £120 on a pillar drill.
But ideally I want to know where I could go for someone to do it for me, or a life hack on how to make it happen at home lol.
I'm sure a local engineerimg shop will happily do that for you. Shouldn't cost a lot. Just give them clear details on what you want.
Try asking a local glass shop if you don't have an engineering place nearby.
One of my locals were able to drill holes in a sheet of glass for me. Aluminium shouldn't be an issue as long as they have the right bits and you've got a template or accurate markings.
I do have a drill press, but didn't trust myself with glass :o
Vice for holding the aluminium, hole punch for where you want the holes. Decent drill and drill bit and you should be fine, maybe get a spray water bottle to cool the metal down as you drill.
Pilot drill first, go 2.5, then 4 then 5 or 6 otherwise your drill will wonder. I've got this contraption ( ot sure what else to call it), that my dad got from somewhere. Its essentially a poor man's pillar drill, you clamp your drill in and use that. I'll try and find a pic.
Something like this. Sorry tried to stick a pic in but it's not working. Looks like it's called a drill press (I assume that's what the guy above meant).
yes get a nice cobalt drill , so that it does the work, I usually use just light bicycle oil on the drill bit,
and secure the metal at foot level above a block of wood, to give best chance of a vertical hole + safety glasses of course.
depends how accurate it needs to be but...
use a scribe to mark the x line along the length of the aluminium then scribe the 4 y axis markings at either end where you want the holes... where the x and y scribe lines intersect creates a point for a centre punch to 'fall' in to
use two squares or known square blocks of wood etc sitting along the x and y axis as a guide for the drill to get the holes straight down the z axis
as said start with a small drill bit to minimize wandering
Thanks all.
There is a local machine shop apparently so I'll phone up Monday.
I have 7 parts to do, and each part is 30-40£ worth of CNC machined aluminium 7075.
The company that makes them have upgraded parts, which look the same, but have extra holes. I want the holes without buying new.
So if this shop fails me, my next choice is as a few mentioned with a block of wood with hole as a guide and a centre punch, or I buy a pillar drill.
These cheap ones I mount the drill in don't look accurate enough from watching YouTube.
Thanks all.
Can you talk to the company that made them and see if they will up-rev them for a small fee. What kind of accuracy do you need, what's it for?
It's aluminium parts for a RC race buggy.
They are made by a company called Tekno.
The new holes allow for alternative roll center setup, so accuracy in the symetry is super important.
