OcUK Staff
- 1 Apr 2014
- OcUK HQ
Phanteks is looking to meet the cooling demands of a high-end gaming system without restricting the space for internal components with the G360A. The scope for cooling is impressive, with mounting options for up to seven 120mm or four 140mm fans, plus a choice of locations in which to mount a radiator. Furthermore, even with all this cooling, there is still plenty of internal space for the latest in gaming hardware. With support for E-ATX motherboards and 400mm GPUs, you’ll be able to build your dream machine in this chassis. Phanteks also caters to the RGB enthusiast, as this case comes with a D-RGB controller, which puts you in control of all your lighting effects, either manually or by syncing it with your motherboard and allowing your favourite software to take control.
Phanteks Eclipse G360A Mid Tower Airflow PC case - Matte White @ £84.95 inc VAThttps://www.overclockers.co.uk/phan...empered-glass-drgb-matte-white-ca-0b8-pt.html
Mid-tower case, E-ATX motherboard compatible, Space for up to 7x 120mm fans, flexible HDD brackets, D-RGB
Only £84.95 inc VAT.
ORDER NOW
ORDER NOW
Free SK 120mm fan included with the case whilst stock lasts!
ORDER NOW
ORDER NOW
