I love the way that says "But if the result is <90% or > 110% it should be of concern"
Show me a single motherboard with any BIOS setting where that readout is not red, i have a setting in my BIOS that switches between the motherboard controlling the power and the CPU controlling the power, it doesn't matter what setting i use HWInfo always reports the same thing, the same thing you are seeing in this screen shot, they say its because the motherboard is under reporting the power values, so how does it still report the same thing when its the CPU controlling power? Also how does it know, if the motherboard in under reporting power levels then where are they getting the real levels from to know that and to know what the percentage difference is? they are not using a voltage meter on the 12v EPS are they???????
IGNORE IT
