New gaming PC
7 Jun 2022
Clitheroe, UK
Hello all and thank you in advance for your advice.
I am looking to get a gaming pc. I've always had laptops previously so I'll also need to get keyboard, mouse and monitor.
I'm hoping to spend around £800 for the lot.
I'd love to be able to play microsoft flight sim, but not sure if this price will buy a good enough machine.
Suggestions of any builds would be most welcome.
My basket at OcUK:
Total: £795.88 (includes delivery: £0.00)​
Couple of b grade deals here to keep under budget, and the cpu isn't amazing. Compared to the other 6 cores on the market as its basically on par with a 3600 from a few years back. But should still do the job. Pretty solid gpu though should serve you well, a decent step up in performance over the 6500xt
Yeah the others are correct in that FlightSim is going to need more than an entry level PC for higher frame rates.
That being said, you can still play the game at lower FPS and it's not a very fast game so you don't need high FPS.
Definitely can play the game on the builds above but it's on of those 'but can it play Crysis/MSFS?' situations where the software is designed to tax current hardware to the max and is really designed to age well with future hardware improvements (4000 series from Nvidia, AM5, etc).
It really isn't. At the £100ish price point an i3 12100/F is a much better option.
yeah, was really just the extra cost on the motherboard that lead me in that direction. I do think at this budget and relatively low end GPU there will be very little difference between them
There is no extra cost on the motherboard. You can get an equivalent H610 board for around £70. There is just no reason to go with the R5 4500.
Thats a really good spec. but i dont think that monitors all that good. You need a decent monitor, Your eyes will thank you over time. Just like having a Good chair. Your health is more important so dont cheap on these 2 items, Get yourself a better monitor
Wonder if its a TN thing? I switched to IPS and much easier on the eyes. Both Acer Predators as well.
IPS panels still have better viewing angles. TN panels are cheap and have fast response times. Good for FPS games, but have inferior image quality and poor viewing angles. they also they have decent color representation and contrast ratios compared to TN panels
