With the release of NVidia's RTX 4000 series expected in the next 2 -3 months the question for many Gamers, especially those who are old cards, is buy now or wait.
The RTX 4000 and Radeon 7000 series cards by reports and rumour will be fart more powerful compared to the previous generation but will be far more power hungry, 600w reported for a RTX 4090, and will also be a higher, MRSP, price compared to the previous generation, though hopefully no more scalper pricing.
Also, it should be remembered that the higher power consumption may require a new PSU as from the mid-range up you may need a minimum 1000W PSU to power your new GPU, hence the release of the new ATX 3.0 standard with 450w+ GPU connectors.
Will the cost of a new next Gen GPU + possibly a new PSU be worth the performance increase, over the current generation, especially as those prices are dropping fast, a mid range 6700XT, can be had for £469.99, or a RTX 3070, for £529.99?
Will you buy now, buy next Gen or wait and compare?
A Pully system?
