Any free software to learn SQL
27 Mar 2016
Bristolian living in Swindon
Hi all
My work have put up job ads for internal staff members to apply for, they need a Junior Data Analyst and I'm wanting to apply for it, I've spoke to someone in the IT department and he said to learn basics of SQL so I'm wandering if anyone knows if there are any free software downloads I could get to help me do some hands on practice aswell as learn with books etc
Thank you
You can get SQL Server from here, free download of Developer or Express, I'd pick Developer but it probably doesn't matter.
Then use SQL Server Management Studio program to connect to your SQL Server and gives you a user interface for doing stuff with it.
Then create a database.
Then create a table.
Then learn INSERT, SELECT, UPDATE, DELETE statements, to manipulate data in your database.
That is 'the basics of sql' imo.
If you take to it, then learn the rest of the stuff at:
You best off just installing it and having a play about with it. :)
Break it, Fix it, Connect to it, Restore it. e.t.c
Yeah will get it all installed and have a mess around with it.. Thank you
Cheers bud, great help will have a look at this lot
I have a few YouTube videos on my watch list so will get watching, thank you
The SQL stuff at my work is pretty basic so I don't touch on it very often but the scripts this guy writes:
Ola Hallengren
And the blog this guy writes:
www.brentozar.com
Are great for SQL knowledge and tips and tricks etc.
We have stuff that relies heavily on SQL but the database is about 100MB so in SQL terms is about as noddy as they come! (luckily for me!)
Edit: Good luck with the testing and job application if you go for it!
Ola Hallengren
www.brentozar.com
Thanks bud I will have a look at that also, hopefully I can get into it as IT has been something I've considered for a while now
I'm to trying to get in to sql and python, for mobile app, specifically android you have solo learn. You have a pay or subscribe option.
Although the suggestion above to install is a good idea as doing it on a mobile, you can get easily distracted I find.
I have a bit of beginner knowledge with Python but compared to many on here it's not much, it's very enjoyable to learn
