I'd side with this. The M135i is by far the most entertaining. I had an A45 for 3 months and the best feature was the panoramic roof. The posterchild for point and squirt modern car syndrome.
Well if you put three understeering, fat, over-assisted bags of manure up against each other and mull it over there's not necessarily going to be a clear winner. There will be a cheaper one, though.
Really depends what you want out of a car. I’d rather save my money on a daily driver. These hatches are too much of a half way house. What about an M2?
The mk8 golf r would also be worth test driving as it’s essentially the same as the s3 only with a more advanced 4wd system. I think the s3 is a nicer looking car though both inside and out.
