That's really low voltage.
I managed to get 2055mhz even on 1.035v. Though after a while it dropped to 2040mhz rock solid. 216 watts max.
not really, 825mv is low, 875mv is still up there
Huh. That's weird - you'd think being binned silicon that there'd be some consistency (I supposed it depends on what they were binning for).
On my Suprim X 3090Ti I settled at 70% power limit, 0.925mV and +1050 on the VRAM - that gets me a 1% drop in performance vs. stock for a 130w reduction in power usage (core is 1995, peaks around 318w - only 18w more than my OC'ed 3070).
What the hell is Nvidia doing, allowing people to turn up the voltage of RTX 3080/3090s above 1.0v in the GeForce Experience software?
Isn't this setting yourself up to fail, given that GDDR6X is 'only' rated to operate with stability at upto 95c?
Do any Ampere cards operate at above 1.0v by default?
