'Pudding' Keycaps needed, but only 5 of them.....
22 Aug 2010
On the Wagon-East Angular
I have a GMMK 2 96% keyboard in ISO UK layout. I also bought the GMMK AURA V2 keycap set that appeared to come with ISO extras (shorter left shift, different size CR button, \| button etc) so I incorrectly assumed it would have the other 5 ISO keys needed, but of course it doesn't lol
So to that end, any ideas where I would find (or even what to search for) black on translucent pudding caps (PBT preferably) with a similar font to the AURA set I have for the following keys `¬ 2" 3£ '@ #~
Glorious themselves do not do these keys, I've already dropped them a message :'(
Cheers
Cheers
I'm in the same boat for the same reason. I never would have thought they'd include the large enter key and \| but then neglect to include another poxy 5 ISO keys.
Cheers
Hey did either of you find a suitable set for this problem?
I have also purchased the GMMK 2 and didn't realise how they neglect the ISO UK layout
No nothing as yet. As has been said it's a **** poor show from Glorious tbqfh
These not what you need
That's the set I got (well, that black top version), and as you can see they've gone to the effort of supplying the correct size Enter key, smaller left shift button and a \| to go to the right of that, but haven't added the 5 additional ISO keys needed, which are
`¬ to replace (`~)
2" to replace (2@)
3£ to replace (3#)
'@ to replace (' ")
#~ to replace (\| )
which is stupid seeing as they've acknowledged the need for an ISO layout!
That's weird, I'm thinking of building a glorious GMMK PRO 75 but if I want these key caps I'll have to build a ansi version as there seems to be no iso ones.
Just to bring closure to this and in case anyone else has the same issue, the Steelseries Prism caps are pretty much identical. The issue with this board is the smaller right shift key, so just a set of the Steelseries wouldn't work. Anyhoo - ` 2 3 \ ' and # now changed to the Prismcaps, so I've got a proper UK layout ISO board. Shame I had to go this route. I contacted Glorious, but they couldn't give a toss. Shockingly bad customer service imvho.
I *might* replace all the number buttons, as the numbers a re a teeny bit larger on the new keys, plus they might stand proud by 1mm maybe? Will see if I cba, but I think it's close enough to not worry about it! So, problem solved, but Glorious customer service is crap!
Yeah UK ISO isn’t supported by most keyboard manufacturers.
It’s technically not just a different set of Keycaps but also a change of layout.
I’ve got a Nuphy Halo65 and I asked them if they were bringing out UK Keycaps and they said yes.
I don’t have the need for Pudding Keycaps so I can just put a sticker with the appropriate symbol over the Keycaps but I can understand why that won’t work for transparent symbols for RGB.
