Massive reply from me incoming. Just got back from 2 weeks in Florida (Disney). Had an amazing time, but 20 days off the bike! Return to work commuting yesterday along with
kiddo trailer really hurt... Then the Zwift TTT was brutal!
Blew up on the Hilly KOM with my HR being crazy high for the whole ride. Really a shock to the system and the start to get back on track.
'Only' gained 3.5kg while away (down to just over 2kg yesterday - water retention from flight?)
I did a round of fund-raising for the event and it has done really well. Rather proud of what its got up to.
Well done mate, that really is the spirit of the thing and really should be what drives it - not cyclists smashing 30mph+ averages due to the closed roads.
Is this just required for offical photography? Any other issues with the lack of visbility?
Probably also used to identify riders in accidents, but might also be used at 'checkpoints' to get everyone through to judge progress. I'd like to think they could also judge congestion with it but unlikely to be that advanced.
Doesn't having it there prevent you from holding the bars?
You ride with your hands on the bars most of the time and not the tops & drops?
The new shoes were generally more comfortable, but last night and still this morning to an extent, I'm hobbling around on my left foot, which feels like the soul is bruised to walk on. I went Extra Wide with these Lakes. Is it possible my foot has too much space, which causes the problem?
Possibly, using insolves in there? Also 'new shoes' issue - they feel different, so you over tighten them to feel more fitted, then the feet suffer due to bad circulation/lack of movement. Especially on a long ride - they tend to go numb, so you don't feel the pain until the circulation is improved later when you take them off.
Yet more reasons why I'd never do a big sportive like that.
But a Sportive with 'fuel stops' should have drinks & food at those stops! One of the reasons I like to do them - pickup some bars/gels/stuff you otherwise wouldn't buy to try out! Some of them I finish with full pockets - but then I might be a prime example on why they where empty, but it wasn't me (this time) guv!
I would say I was perfectly prepared. Prepared for them to have some bananas, cakes, biscuits and such, as you would expect from even a simple Sportive.
Exactly! Even a local charity '£5 to enter' ride will have all of the above at every stop.
Would you do it again next year? If there is a big OCUK I'd love to tag along. Though I'd bring the speed down!
Would be better to find another Sportive for it - less busy, better organised, cheaper, better route, better facilities, etc etc.
£90 or £100 wasn't it? Or was that just the ballot for the non-charity spaces?
Can you tubeless guys spec me a decent but not super expensive track pump that'll be good enough to seat a tubeless tyre.
My old trusty that I've had the last 7 years is starting to play up and needs the head held onto the valve to work. So I may as well get a new one but don't really fancy spending the £100 on one unless I need to.
Think you've found it, but the Joe Blow is great. Got one here a few years back and it's the best track pump I've owned (but I've only had 3?4?). Think they're a Topeak brand? A tyre inflator is excellent (and I've got one) but the tyre & rim combo you're using along with the technique will determine how easy things are to mount far more than the track pump you're using.
Topeak Joe Blow and use a CO2 inflator for the occasions tubeless tyres won’t seat properly.
I did make a ghetto tubeless inflator out of a coke bottle at one point. It was a fun project but the CO2 is probably safer.
Agreed. I went the CO2 route, used a bunch of them, then ended up picking up an inflator anyway and it is excellent. But last tyres I mounted (Pirelli P-Zero on Zipp 303 S) didn't need it.
There is something to be said for just doing what you want to do in order to enjoy something. I used to be really into bouldering and would go 3 times a week and if I didn't I would be a bit grumpy and feel like I was missing out, getting weaker etc and I wouldn't enjoy sessions if I wasn't climbing well.
When COVID hit and all the walls closed for months I just got out of the habit and it was fine. I now climb once a week and really enjoy it. I climb about 90% as hard and enjoy it more because there is not pressure to perform or improve at any pace.
If training hard for cycling helps you to enjoy it more and the sacrifice is worth it then go for it but ultimately we generally do all these things to enjoy life. If you are forcing yourself to do something that you don't want to do for some perceived greater value down the road, perhaps you need a rethink. Its not like forcing yourself to train to get a better job where the benefits are forever and don't require constant upkeep. Any exercise gains are borrowed up to a point and if you stopped for a few years you would lose most of them.
Basically, do what is right for you and don't feel pressured to do something because you think you want to do it.
This is an amazing post mate and really really well written. Exactly on the money where I am at right now and have been the last couple of years. I've been even more laid back about it - riding more for fun and zero pressures. I've actually found more increases to my performance(s) from it, than the times I tried to ride (& eat/drink) more structured and strictly while certainly having far more enjoyment.
Thanks for the route help
@UTmaniac. Rode it on Friday:
https://www.strava.com/activities/7249104627
In the end, I was quite early for the Hythe Ferry. It was literally all closed up when I got there and I think first one wouldn't leave until around an hour later so I rode into Southampton on the annoying shared use path. At least I wasn't on the dual carriageways until that point like last time. Getting out of Southampton was relatively pleasant at that time. It was a long old day in the end and very rolling but nice enough. A little gutted I didn't get the SW/W wind I had hoped for
Great riding mate, chapeau!
Anyone using/used the Schwable Pro One tyres? Any reason to avoid them? Seems the Continental GP5000S are out of stock in most places and Mantel have the Schwalbes for £75 a pair.
Can recommend the
Pirelli P-Zero. I ended up with some 'PAS Normal Studios' branded ones from Sigma just to get the price down a bit - £62 a corner rather than £70 back then,
but they're no longer available.
