5800x PBO won't boost past stock
19 Oct 2002
Torbay, Devon, UK
Hi im not used to this AMD overclocking.
The last I OC'd was a 3770k lol.
So I've set the TDC,EDC,PPT in the BIOS (stock setting. I've done a negative 25 on each core. It will run cinbench 23 multicore fine. 4375mhz I've then added anything from 50 to 200 MHz, and it doesn't change the clock. The TDC,EDC,PPT are all in the mid 66%.
I just don't know why it won't boost higher
Please help a noob.
Make sure voltage is set to auto, in fact all you need to set is pbo and curve optimizer, everything else can stay stock, oh add the 200mhz on the o/c
Before setting negative 25 in the curve optimiser did you check lower negative settings? If not start at 0 and work down untill you can get the highest negative number without errors.
