- 21 Jul 2005
- Officially least sunny location -Ronskistats
kW are not the same as kWh. We're talking about power here, which is measured in kW. kWh is used to measure energy - if you powered a 1kW kettle for one hour you'd have used 1kWh of energy. If you run a 2kW kettle for half an hour, you've still used 1kWh.
Not trying to be condescending or anything but I noticed in a few of your posts on this topic you've used kWh instead of kW so just wanted to nudge you in the right direction![]()
Apparently overthinking.
They also already make these camping ones so its cheap. I can wait an extra 180 seconds or whatever it is if it means controlling local generation. That's the whole point.
