Minor scrape/scratch repair?
3 May 2012
Wetherspoons
Hi guys,
Already gone over this with t-cut and a microfiber cloth. Pictures below, it really isn't too bad and I'm not that bothered, but wondering if there is anything further I could try?
I wondered if getting some kind of buffing wheel drill attachment or some other kind of cutting compound/polish?
I don't want to spend much, but if anyone can suggest anything cheap and easy that might help?
I can't really see what you are seeing but I'd recommend trying Meguiar's G17216EU Ultimate Compound. Worked well for me with little effort.
Much of that should polish out and if you use some thick wax it will fill a lot of it in. I wouldn't bother getting it reprayed either, more hasstle than it's worth.
Just to update this thread. Was up early this morning thought I'd get out and give the cars a good clean before it's gets too hot.
Was giving them a good go so was rumaging through the shelves in the garage trying to use up all those things you get given for Christmas but don't normal use (dash shine) etc.
Anyway came accross this stuff that I bought many years ago when I was restoring an old motorcycle:
And you can see the results compared to the above pictures:
