Ukraine Invasion - Please do not post videos showing attacks/similar
Status
Not open for further replies.
A new artillery system might be coming to Ukraine as the Armed Forces now expects 18 105 mm L118 howitzers from the US.
The reason for choosing the L118 is its much greater mobility (2 tons), which is crucial in the counter-battery fight.
The L118 can reach the enemy at a distance of 17.5 km conventional (19.5-20.5 rocket-assisted).
Compared to the 122-mm Soviet systems, the 105-mm outranges them as the D-30 howitzer and 2C1 Gvozdika SPG firing distance is 15 km.
That's pretty cool, firing range is still decent and you can tow it with a Toyota
I don't think I can post it but there's a video doing the rounds of a Russian anti aircraft missile launcher firing a BUK missile which then proceeds to do a 180 turn and takes out it's own launcher.
I missed that initially but let's just hope that their nukes decide to do the same thing!
Either that or we just tested some nice new jamming tech that worked a treat.
Around 18 Riverine Patrol Boats from USA is heading to Ukraine.
The patrol boats are largely to protect the riverways (will likely be used in the Dnipro River close to Kyiv) but can also be used in coastal areas.
Ukraine’s current riverine force is largely made up of converted fishing and pleasure vessels, so these patrol boats will likely be a highly welcome addition to their forces.
25-Jun-2022 06:51:05 - UK Military Intelligence: Ukraine Is Likely Re-Configuring Its Defence of the Sieverodonetsk-Lysychansk Sector
25-Jun-2022 06:52:37 - UK Military Intelligence: Since Start of June, Russian High Command Has Likely Removed Several Generals From Key Operational Roles in War in Ukraine
25-Jun-2022 07:49:12 - UK’s Johnson: Concerned That Economic Difficulties in Europe Will Put Pressure on Ukraine to Make a ‘Bad Peace’
25-Jun-2022 07:49:53 - UK’s Johnson: If Putin Gets His Way in Ukraine, That Would Be a Long-Term Economic Disaster
25-Jun-2022 11:00:14 - Ukraine Military Chief: US-Supplied HIMARS Rocket Systems Already Hitting Targets in Occupied Ukrainian Territory
25-Jun-2022 12:10:47 - Mayor of Ukraine’s Sievierodonetsk: Ukrainian Troops Have “Almost Left” Sievierodonetsk
25-Jun-2022 12:11:26 - Mayor of Ukraine’s Sievierodonetsk: People Sheltering at Azot Chemical Plant Will Remain There Until Fighting Ends
25-Jun-2022 15:17:14 - Mayor of Ukraine’s Sievierodonetsk: City Is Fully Under Russian Occupation
25-Jun-2022 15:19:13 - Mayor of Ukraine’s Sievierodonetsk: It Is Not Possible to Leave City to Ukraine-Controlled Territory, Only to Russia-Controlled Areas
25-Jun-2022 15:43:14 - Russia’s Putin and Belarus’ Lukashenko Discussed Situation With Global Supply of Fertilisers — RIA
25-Jun-2022 16:25:03 - Putin to Lukashenko: Russia Will Give Belarus Iskander M Cruise Missiles
25-Jun-2022 16:20:56 - Ukrainian Military Intelligence Chief: Ukraine Is Regrouping From Sievierodonetsk to Higher Ground in Neighbouring City of Lysychansk to Gain a Tactical Advantage
25-Jun-2022 16:20:56 - Ukrainian Military Intelligence Chief: No Longer Possible to Hold the Line in the Ruins and Open Fields of City of Sievierodonetsk
25-Jun-2022 16:20:56 - Ukrainian Military Intelligence Chief: Ukraine Will Continue Defence of Area From Higher Ground in Lysychansk
25-Jun-2022 16:27:26 - Ukrainian Military Intelligence Chief: No Point in Waiting For Russia to Exhaust Its Offensive Potential, Russia Has Access to Large Mobilisation Resources
25-Jun-2022 16:27:26 - Ukrainian Military Intelligence Chief: Russia Conducting Covert Mobilisation by Bringing in Reserve Forces
25-Jun-2022 16:27:26 - Ukrainian Military Intelligence Chief: Only Path to Ukrainian Victory Is Through Military Force
25-Jun-2022 16:27:26 - Ukrainian Military Intelligence Chief: Russia’s Operation in Ukraine Involves 330,000 Personnel, A Third of Russia’s Armed Forces
25-Jun-2022 16:27:26 - Ukrainian Military Intelligence Chief: 330,000 Figure Includes Technical Staff As Well As More Than 50% of The Russian Army’s Combat Forces
25-Jun-2022 16:29:05 - Ukrainian Military Intelligence Chief: Ukraine Should See Visible Results of Counteroffensive in Southern, Occupied Region of Kherson From August
25-Jun-2022 16:29:05 - Ukrainian Military Intelligence Chief: Kherson Counteroffensive Will Be Difficult, but It Is Possible
https://www.reuters.com/world/europe/ukraine-fight-higher-ground-lysychansk-spy-chief-2022-06-25/
25-Jun-2022 16:41:47 - White House Spokesperson Kirby: Knows of No Bilateral Discussions With Russia on Food Security
25-Jun-2022 16:46:54 - General Staff of Ukraine Armed Forces: Ukrainian Troops Have Withdrawn From Sievierodonetsk
Reckon the Russians will try to cut off Lysychansk next. There's a big salient begging to be cut off behind it.
Now that Ukraine are getting longer range fires I don't think it will be that easy for Russia as they'll be getting blasted from well within Ukraine's anti-air defence. Hopefully they get much more of these systems to really mess up Russia's ability to advance at all.
They might solidify south of Lysychansk so as to push on Bakhmut - if Bakhmut falls it will be a major issue for Ukraine as it is a major hub for the military in that area.
There is a media blackout in the Kherson region, but despite this the Kyiv Independent just made a post saying Ukraine is now attacking inside the Kherson city
That would be awesome, I've been hoping for some good news from Kherson, IIRC the media blackout started a few days ago and they were already in possession (or almost) of one of the last towns on the way to Kherson city, if they're able to take Kherson then game over for all the Russian forces that side of the river, they're cut off - potentially mass surrenders from them.
Also means the rest of Kherson south of the river is potentially able to be taken + Zaporizhzhia oblast too... it's kinda key if they want to push the Russians back to Crimea/pre-2022 lines.
With comparatively little major/breaking news from Ukraine right now and with Roe vs Wade taking a lot a particular groups attention away, I wonder how quiet this thread (and Ukraine chatter in general) will get over the next few days?
Same as ever, twitter and other forums etc are awash with news from Ukraine.
What you are saying is the west are losing interest because of the above you mentioned right?...
No, what I am asking is this..........
1. I'm "asking" not "saying".
2. I'm asking about "this thread (and Ukraine chatter in general)" not "the west"
3. I'm asking about "the next few days" not about the West "losing interest"
I agree with you that Twitter, reddit, Telegram etc are still busy with Ukraine news right now but I was asking about the next few days and what we think might happen, thats nice and simple to understand I think.
Status
