- 29 Oct 2002
Ok. After some recent discussion and disappointing info around certain brands of PSU, I pulled the trigger on the Corsair HX1000, which arrived today. For the first time, I was provided with a single/dual rail option which, after doing some reading, basically either gives me the full ampage (around 90A) on all 12V circuits with single, or 40Amp caps on the rails with multiple selected. I have an rtx 3080 Gaming OC, which after some investigating can have a max wattage of around 560W (note this is full on stress testing, not "normal" use). Doing some quick maths, 560/12 works out at around 47Amps max, I'd therefore not be able to user multi-rail 12V @40A monitoring as if the card hit peak the OCP would kick in, does that sound about right?
Sorry for the wall of text, input and/or confirmation would be appreciated
DB
DB
