What's with all thecare to expand?
Thanks in advance
Doesn't seem too bad, just make sure the G99 application in and either allowed/denied, before they start work!
Also, ask for an itemised quote showing the full list of items being specified and their costs
If you want a battery, then buying now should save you the VAT as you're buying a complete install. The cost to add a 2nd battery isn't bad, but then the cost to install the first battery isn't great and quite expensive. I see someone mentioned these batteries can only output 2.4kW max, which is pretty poor and would write these batteries off for me.
Definitely get some more quotes and ask for those to be fully itemised also!
So all in I reckon it'd save me £1-2 per day having a battery, assuming an average £1.50 that's £547/year saving against a £5,310 cost for a piece of kit that has a useful economic life of 10 years so it just about breaks even. I can get a far better return on that £5,310 by investing it.
Abyss has certainly done some calcs, only you will know if it's worthwhile.
Although I don't agree with the 10year useful life of a battery. They won't suddenly turn into a damp squid or die at that point, they'll still have loads of useful capactiy available.
