New car shoes. I've been using Michelin Pilot Sport 4 tyres for a while now and fancied a change to Michelin CrossClimate 2.
I had those on my Skoda and they are good tyres but the road noise increased significantly.
Fair enough. They've to be quieter than the Michelin Pilot Sport 4's I've been rocking for years though. The road noise was brutal to begin with, but in the end I just got used it.
@nam - are these things pretty silent? My missus has to sleep with the window open atm, and it bothers me as the road traffic keeps me awake. We’ve tried a fan but that’s even worse. How quiet are these fanless fans? And how much did it actually cost you after your discounts?
Try one of these Ahleckz.
Linky
I sleep with a fan on pretty much all year round and a normal sized fan drives my other half insane. She has been fine with something like this, very localised for airflow (if you have a headboard you can clip it on to) and very quiet when on the lowest setting.
It's not exactly the same as the one I have as that one isn't listed anymore, but it's essentially the same thing.
Just to add, that this one...
Linky 2
Is also excellent, and I think it moves quite a lot of air for very little noise. My main problem with it is the blue speed indicator seems to stay on when it's set to 0 and not actually running. Nothing a bit of tape can't solve though. That or you find one that is the same and doesn't have that problem!
First order with American Fizz. I heard Mexican Coca Cola was really good compared to ours.
You should do a double blind test, get a glass bottle from here and compare (but drink it out of a glass).
p.s.
Nice, which one is it?
Love my Mirra 2
Brand spanking new Aeron, and it's like sitting on an ickle fluffy cloud :D
I very very nearly bought the Cosm instead, but the place I bought it from said the Aeron would suit my needs better.
I've got to say that difference in quality and adjustments compared to my current gaming chair is almost undescribeable.
I'm now going to take my 7 month old Secretlab Evo 2022 into the garden, set fire to it, then blow it up, and then bury it.
Or I'll probably sell it, but either way, good ******* riddance.
Good call @JonRGV250 Mine must be getting on for 20 years old and still feels like new (and when dusted looks it too). Saved me money over the long run as the £100-£150 office chairs just used to break after a couple of years - and NOT suffering back pain caused by bad posture whilst sitting at the desk all day is incalculable.
Same here, mine is defo 20 year old. Had to change the ballhead joints for the seat twice as they eventually broke (I used to be quite big) but replacement parts are easily available, and 10 quid each!
Once thing I bought a while back is a headrest. The 'official' one; it's not /perfect/ but quite comfy - should have gotten it years before!
You can also change the wheels, there are replacement sets for various surface, also, cheap and easily available.
Well worth the money!
