That's what I'd have done too.Too late nowchopped it, far enough away from the nearest window which rarely gets opened anyway.
Good - even better the scaffold was still there to make it a far simpler task!!proper gloomy morning but ticking over at 2kwh.![]()
I think its because it would affect the whole strings efficiency and this would be most during the shorter days when the shadow is longest.Would that small shadow really make a noticeable difference?
Yep, got up and took down the TV aerial and cleared the gutters when they left yesterday, so thats something I won't need to do up a ladder!Good - even better the scaffold was still there to make it a far simpler task!!![]()
@HungryHippos guys were really good, just keep them topped up with Tea and Coffee!
With micro inverters, or optimizers - no. However if the panels are wired in series then the section of the panel in shade acts against the whole set of panels it's wired in with.Would that small shadow really make a noticeable difference?
Just left mine on all day now at 20c ticking over and meant I've had a nice comfy day. DNO came back on the 20th as predicted and they had it booked in the day after, so a week?Awesome work looks great!
Definitely looking forward to mine getting added, cut down those bills a bit, my last utility bill for a month was £200 actual usage so £6.66 per day (evil number!).
How soon after DNO were they out? I have 28/07 for my "no later than" date for approval, so hoping to get it all in ASAP to stop paying the grid people so much
Bonus of also being able to use my AC more often without the grid, which makes it far more useful than it is now when I only use it really warm days when I need it due to cost.
25kwh so far.. that really is quite something. Do you finish on around 32-34kwh at this time of year as a result then? Have you worked out what the winter should yield from this 17? Panel configuration yet based on other user data for this sort of set up or are you in the dark with it?Just left mine on all day now at 20c ticking over and meant I've had a nice comfy day. DNO came back on the 20th as predicted and they had it booked in the day after, so a week?
I've generated 25kwh since 05:15 this morning (20 minutes after sunrise) with enough generated from 06:15 to cover my base load.
Find out at the end of the day, still getting 4kwh atm, and should be generating for another 3ish hours yet, so will probably be about that. First day with it, I did have it somewhere but can't find it, but somewhere around 5-8 kwh on average per day in the deepest, darkest months of the year.25kwh so far.. that really is quite something. Do you finish on around 32-34kwh at this time of year as a result then? Have you worked out what the winter should yield from this 17? Panel configuration yet based on other user data for this sort of set up or are you in the dark with it?
Find out at the end of the day. First day with it, I did have it somewhere but can't find it, but somewhere around 5-8 kwh on average per day in the deepest, darkest months of the year.
Got my panels installed - the installer has done a great job.
I'm glad you clarified.of your house
Started dropping off about 16:30 as the sun moved round to the west and is now at about 1.5kwh even though there appears to be no direct line of sight and 36kwh produced overall, so seems like a good day will be 40+ and even a cloudy day 1.5kwh was the minimum load from 08:00 to 11:00 before the sun came out proper.I’ll keep an eye on this then as real world use be the nonsense most quote when selling differs significantly.
With 6kw at hand, you could argue it makes very little difference. However seeing how easy the fix is, you may as well do it now.
