PSU or Motherboard faulty?
23 Mar 2011
At work yesterday, the pc I use in the workshop (my old personal one) just didn't turn on all of a sudden. Literally nothing.
Tried a different plug socket, tried the cable from the monitor but nothing (monitor powers on with the same cable etc)
Opened it up and reseated all the connections to the mobo, tried all I can think of.
Does this sound like the PSU is done? Hope so, over the motherboard?
Thanks all
Does sound like it could be the PSU if your getting no power at all... I'm guessing you don't have a spare to try?
One stick of RAM at a time, switch out one with the other then try again.
do test with minimal components install
Could be PSU, could be mobo/BIOS battery, could be something else.
PSU's capacitors failing would more likely show up as increasing cold boot problem over time.
Though of course PSU can suffer also sudden death.
"BIOS" battery is known for being able to suddenly stop PC from booting besides other wacky symptoms.
And at least changing it would be cheap attempt.
Hey all sorry for the delay
Got round to trying the above suggestions.
The paperclip pay thing worked to get the PSU fan spinning so I guess that proves that is fine.
However once plugged in to the motherboard, it doesn't come on at all.
I've disconnected all components etc and still nothing, replaced the battery etc
So I'm pretty sure it has to be the board? It's aging now tbh but has to be it surely?
You trying to power it via a power switch on your case?
If so, have you tried powering it up using whatever it is on the motherboard, just in case its a faulty power switch, it is a moving part after all.
Otherwise no obvious signs on the motherboard of damage, bulging capacitors anywhere?
Yes use a screwdriver to bridge the pins on the motherboard power on header to rule out a faulty case power switch. Unplug everything. Except memory and cpu including io headers and see if you get life. Try single memory in every slot. Alternate the memory . Psu might start up wth pin test but might still be bad I reckon...you can get psu testers under £15 which check voltages.
