Wonder how long it would take before as a reaction they started using palletised loads more, keeping depots more spread out/better defended and so on.
Probably a while, from what I understand Russians simply don't use palletised/mechanical assistance like the west does, and it takes a long time to update to make use of it as for example apparently something like 25% of US "5 ton" trucks have cranes to assist, almost all of the western heavy artillery/rocket launch vehicles are designed with it built in and the shipping crates to match.
It's not even "just" the military, apparently much of their internal freight doesn't use it, which means they don't even have a large supply of forklifts, especially the sort of forklifts that can operate safely (or at all) on uneven ground in civilian use to "borrow".
At this point I'm starting to get surprised that we're not seeing pictures of the Russians loading all the forklifts they can onto the back of transports but I don't know how much Ukraine uses them (I suspect if the Ukrainians think they might be of use to the Russians they'll start destroying/damaging any they can before moving out of an area to stop them of being useful to the Russians).
The russians still rely very heavily on wooden packing for their munitions, which makes things even harder as those wooden crates aren't really suited for using with pallets (not necessarily designed to fit on them/be secured easily), whilst western munitions tend to use metal/plastic transport frames that are both specifically designed with palletisation methods in mind (IE places for lifting mechanisms/fork lifts to get a hold), and higher density in transport as if you're using mechanised systems you don't need to worry about weight so much and have been for decades, so even if the Russians started to do it now it would be a makeshift effort and likely not anything like as efficient.
I was watching a video of one of the US rocket systems and from memory it was almost entirely automated so the delivery truck could drop the rockets off quickly, move away and then the launch vehicle just required someone to attach something like 4 quick release cables to each shipping pod.
