- 20 Jul 2009
- The bleak North East arm pit of Britain
I’ve just had a couple of quotes..
One wants to install 18x panels for 7.2kw system with 6kwh battery pack and everything all installed with full parts and labour warranty with monitoring for 10 years. This is for what they call “day light panels” so as long as they get some light they work pretty well even in winter (apparently).
£15319 all in.
Another wants to install 12x panels for a 4.8kwh system with 10.4kwh battery pack and everything installed with a 12 year panel warranty, 10 year battery warranty and a 5 year labour and other parts warranty.
£11769 all in.
Now, I like the idea of the additional power to sell to grid and the facility to do washing, car charging, you name it when ever you need it without ever really spending a penny on power in the day, only really using power in the dark hours from battery (which can then be charged in my 00:30 to 04:30 window on the cheap) so a saving all the same.
I’m torn on the solutions.
Which would you think is the better option? I’m thinking the more costly solution will allow for the addition of a second PHEV or fill electric at the home without really having a concern for charging as they will just go on trickle during the day and full charge on the cheap bracket (assuming I can automate that).
Which is the better value in your opinions ?
£15319 all in.
£11769 all in.
