OcUK Staff
- 1 Apr 2014
- OcUK HQ
With eight years of experience behind them Streacom has developed a new vertical, small form factor case that has been explicitly designed to showcase high-end hardware. The Streacom DA6 takes this plan and presents it with a tubular aesthetic, incredible versatility, and future-proof features. Standing at 431mm tall, this case has a footprint of 215mm by 215mm with an interior that has been optimised for hardware placement. Thanks to its open design, this case has phenomenal airflow and cooling capabilities, which can be further bolstered with support for both fans and radiators. There are many configurations you can take advantage of with the Streacom DA6, how you build it is up to you.
Streacom DA6 SFF Vertical Open Frame Steel PC Case - Black @ £124.99 inc VAT https://www.overclockers.co.uk/stre...open-frame-steel-pc-case-black-ca-05z-sr.html
Vertical open frame case, SFF, GPU up to 323mm long, Supports Mini-ITX Motherboard, Includes 8 x universal brackets, 19.9L volume
Only £124.99 inc VAT.
ORDER NOW
Streacom DA6 SFF Vertical Open Frame Steel PC Case - Chrome @ £124.99 inc VAT https://www.overclockers.co.uk/stre...pen-frame-steel-pc-case-chrome-ca-060-sr.html
ORDER NOW
Streacom DA6XL SFF Vertical Open Frame Steel PC Case - Black @ £134.99 inc VAT https://www.overclockers.co.uk/stre...open-frame-steel-pc-case-black-ca-061-sr.html
Vertical open frame case, SFF, GPU up to 358mm long, Supports Mini-ITX Motherboard, Includes 8 x universal brackets, 21.5L volume
Only £134.99 inc VAT.
ORDER NOW
Streacom DA6XL SFF Vertical Open Frame Steel PC Case - Chrome @ £134.99 inc VAT https://www.overclockers.co.uk/stre...pen-frame-steel-pc-case-chrome-ca-062-sr.html
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
